ClamAV failed to restart after upgrading KeyHelp  [SOLVED]
Tony20
Post by Tony20 »
STOP - Please read the next lines carefully!
1) Please fill out the post template below completely!
2) The members of this forum provide their valuable time to help! In return, please provide as much information as possible and be specific in your error description. Posts that show little initiative will probably not get good responses!
You may remove this top portion of the post template.
However, do not remove the following post template under any circumstances.
(Problems not related to KeyHelp belong in the Offtopic forum)
(e.g. Ubuntu 20.04)
Ubuntu 24.04 (64-bit)
(e.g. none, OpenVZ, KVM, XEN, etc.)
none
(e.g. 22.0 - Build 2366)
25.0 (Build 3394)
Expected result
Actual result
Steps to reproduce
Additional information
(e.g. recent changes to the server, excerpts from log files (/var/log/*, /var/log/keyhelp/php-error.log, etc.))
error
"Failed to restart clamav-daemon.service: Unit clamav-daemon.socket is masked"
When I try to start the service in the control panel (Server Service Management) I get this error
"The operation could not be completed. Please check the necessary permissions."
omexlu
Re: ClamAV failed to restart after upgrading KeyHelp
Post by omexlu »
Please take a look here:
viewtopic.php?p=52866#p52866
Should be fixed soon in 25.0 to :)
Just to be clear, the fix is not part of 25.0
Re: ClamAV failed to restart after upgrading KeyHelp  [SOLVED]
This is now fixed with KH 25.1.
