Problem with Dovecot plugins
cr4zyk1d
Post by cr4zyk1d »
(Problems not related to KeyHelp belong in the Offtopic forum)
(Debian 12.9 (64-bit))
(KVM)
25.0 (Build 3398)
After every update or restart of Dovecot, the configuration is reset to default, removing the fts_xapian plugin. Attempts to add it via local.conf do not work, as dovecot.conf takes priority. Even when creating custom configuration files like 1-my-config.conf, the settings are still overridden.
Expected result
The fts_xapian plugin should remain enabled after an update or restart of Dovecot, allowing fast email search.
Actual result
The fts_xapian plugin is removed, forcing manual reconfiguration after every update.
Steps to reproduce
  • Edit local.conf to add mail plugins.
    Restart Dovecot.
    fts_xapian is not enabled.
    Manually add fts_xapian to dovecot.conf.
    Restart Dovecot, and fts is now enabled.
    After an update, the configuration is reset to default, removing all custom plugins.
    Custom configuration files (e.g., 1-my-config.conf) do not persist settings.
Additional information
The issue occurs because dovecot.conf is overwritten during updates. Attempts to prevent this using local.conf or additional custom config files have failed. A method to permanently retain fts_xapian is needed to avoid manual reconfiguration after each update.
Re: Problem with Dovecot plugins
the local.conf is the rigth place for your own configuration.
Check that it is inclued by dovecot.conf
cr4zyk1d
Post by cr4zyk1d »
It's included, but 'mail_plugins =' here forces the config and treats it as a priority, which results in disabling fts_xapian, even though it has its own line in local.conf:
mail_plugins = $mail_plugins quota fts fts_xapian
Is simply adding this line in local.conf enough? Does it need to be defined anywhere else?
I don't know how to prevent this, but it happens periodically. Here is the dovecot.conf configuration:
# Dovecot configuration file.
# This file was generated by KeyHelp.
# Do not modify this file due it may be may be overridden by future releases.
# You can use 'local.conf' for your own configuration.
# Debug mode.
#auth_debug=yes
#mail_debug=yes
# Listen for connections on all IPv4 & IPv6 interfaces.
listen = *, [::]
# Mailbox locations.
mail_location = maildir:/var/mail/vhosts/%d/%n
mail_privileged_group = mail
# Plugins.
# Include configurations.
!include conf.keyhelp.d/*.conf
# Include custom configurations.
# Put your own custom settings in the following file, it will remain untouched by KeyHelp updates.
!include_try local.conf
