Postfix: manuell upgraden und lib-Fehler beim start
f0tuser3
Post by f0tuser3 »
Wie bekomme ich postfix geupdated, mind. auf Postfix stable release 3.10.0. ?
Aktuell ist 3.8.6 drauf.
Und es kommen (seit dem ubuntu upgrade) einige Warnmeldungen beim Startup
postfix: Postfix is using backwards-compatible default settings
postfix: See http://www.postfix.org/COMPATIBILITY_README.html for details
postfix: To disable backwards compatibility use "postconf compatibility_level=3.6" and "postfix reload"
postfix/postfix-script: stopping the Postfix mail system
postfix/postfix-script: warning: /var/spool/postfix/etc/localtime and /etc/localtime differ
postfix/postfix-script: warning: /var/spool/postfix/etc/resolv.conf and /etc/resolv.conf differ
postfix/postfix-script: warning: /var/spool/postfix/etc/services and /etc/services differ
postfix/postfix-script: warning: /var/spool/postfix/lib/x86_64-linux-gnu/libnss_hesiod.so.2 and /lib/x86_64-linux-gnu/libnss_hesiod.so.2 differ
postfix/postfix-script: warning: /var/spool/postfix/lib/x86_64-linux-gnu/libnss_systemd.so.2 and /lib/x86_64-linux-gnu/libnss_systemd.so.2 differ
postfix/postfix-script: warning: /var/spool/postfix/lib/x86_64-linux-gnu/libresolv.so.2 and /lib/x86_64-linux-gnu/libresolv.so.2 differ
postfix/postfix-script: warning: /var/spool/postfix/lib/x86_64-linux-gnu/libnss_compat.so.2 and /lib/x86_64-linux-gnu/libnss_compat.so.2 differ
postfix/postfix-script: warning: /var/spool/postfix/lib/x86_64-linux-gnu/libgcc_s.so.1 and /lib/x86_64-linux-gnu/libgcc_s.so.1 differ
postfix/postfix-script: warning: /var/spool/postfix/lib/x86_64-linux-gnu/libnss_dns.so.2 and /lib/x86_64-linux-gnu/libnss_dns.so.2 differ
postfix/postfix-script: warning: /var/spool/postfix/lib/x86_64-linux-gnu/libnss_files.so.2 and /lib/x86_64-linux-gnu/libnss_files.so.2 differ
postfix/postfix-script: starting the Postfix mail system
24.04.2 LTS (GNU/Linux 6.8.0-55-generic x86_64)
KeyHelp : 25.0 (Build 3398)
Operating System : Ubuntu 24.04 (64-bit)
Danke und Grüße
Re: Postfix: manuell upgraden und lib-Fehler beim start
Moderativer Hinweis:
Thread nach Off Topic verschoben, da kein Bezug zu Keyhelp vorhanden/erkennbar ist.
Hinweis: Die Kompatibilität von Postfix 3.10.0 mit KeyHelp muss nicht gewährleistet sein.
Aktuell ist die maximale Postfix-Version, mit der KeyHelp getestet läuft die 3.8.6 (so wie es die Standard-Version von Ubuntu 24.04 ist).
Alles darüber hinaus ist nicht getestet und ich kann nur davon abraten.
f0tuser3
Post by f0tuser3 »
mh, schade. dachte man kann das einfach bei ubuntu hochziehen?
woher kommen dann meine aktuellen lib fehlermeldungen?
Habe noch nichts bezüglich upgrade versucht...
f0tuser3 wrote: Fri 21. Mar 2025, 23:27 mh, schade. dachte man kann das einfach bei ubuntu hochziehen?
Was versprichst du dir denn von der aktuelleren Programmversion?
f0tuser3 wrote: Fri 21. Mar 2025, 23:27 woher kommen dann meine aktuellen lib fehlermeldungen?
Von welchen Fehlermeldungen sprichst du? Wenn du den Snippet aus dem Startpost meinst, das sind keine Fehlermeldungen, sondern nur Warnungen bzgl. des Kompatibilitätsmodus von Postfix.
f0tuser3
Post by f0tuser3 »
Guten Morgen,
ich möchte dieses Feature nutzen:
Privacy: With "smtpd_hide_client_session = yes", the Postfix SMTP server generates a Received: header without client session info. This setting may be used with the MUA submission services (port 465 and 587).
ja, die kompatibilitäswarnungen sehe ich schon auch.
die folgenden lib warnungen kommen erst seit dem kürzlich von keyweb durchgeführten ubuntu upgrade:
Was würde denn ein reboot bewirken? Tauchen danach die Fehlermeldungen auch noch auf? Postfix sollte dann eigentlich gezwungen sein, die Dateien im /spool/ zu erneuern.
Alternativ kannst du auch einfach mal probieren, die genannten Dateien an die entsprechende Stelle im /spool/ Verzeichnis zu kopieren.
Post by Fezzi »
Ok, nur zu meinem Verstaendniss...
Ich will nichts upgraden aber gerne die Fehlermeldungen verstehen.
Diese Fehlermeldungen tauchen bei mir auch auf allen Systemen auf (Ubuntu 22.04 und Debian 12.10) ... geaendert oder upgedated habe ich nichts und es ist mir nur gerade eben bei einem Neustart von Postfix auf einem System aufgefallen.
Wenn ich es richtig verstehe dann handelt es sich hier um "normale" Fehlermeldungen. Korrekt?
blickgerecht
Post by blickgerecht »
Habe auch diese Meldungen gefunden, nachdem ich das hier gelesen hatte:
Mar 20 20:13:05 postfix/postfix-script[1315]: warning: /var/spool/postfix/etc/hosts and /etc/hosts differ
Mar 20 20:13:05 postfix/postfix-script[1522]: warning: /var/spool/postfix/lib/x86_64-linux-gnu/libnss_compat.so.2 and /lib/x86_64-linux-gnu/libnss_compat.so.2 differ
Mar 20 20:13:05 postfix/postfix-script[1525]: warning: /var/spool/postfix/lib/x86_64-linux-gnu/libnss_hesiod.so.2 and /lib/x86_64-linux-gnu/libnss_hesiod.so.2 differ
Mar 20 20:13:05 postfix/postfix-script[1527]: warning: /var/spool/postfix/lib/x86_64-linux-gnu/libnss_files.so.2 and /lib/x86_64-linux-gnu/libnss_files.so.2 differ
Mar 20 20:13:05 postfix/postfix-script[1529]: warning: /var/spool/postfix/lib/x86_64-linux-gnu/libnss_dns.so.2 and /lib/x86_64-linux-gnu/libnss_dns.so.2 differ
Mar 20 20:13:05 postfix/postfix-script[1531]: warning: /var/spool/postfix/lib/x86_64-linux-gnu/libnss_systemd.so.2 and /lib/x86_64-linux-gnu/libnss_systemd.so.2 differ
Mar 20 20:13:05 postfix/postfix-script[1533]: warning: /var/spool/postfix/lib/x86_64-linux-gnu/libresolv.so.2 and /lib/x86_64-linux-gnu/libresolv.so.2 differ
Daher auch von mir die Frage: Kann ich das so lassen? Möchte ungern an mehreren Server etwas auf Verdacht ändern, wenn erstmal alles in Ordnung ist :shock:
Grüße
Roland
Post by Fezzi »
Ok... AI sagt.. nicht wirklich kritisch... da bei mir alles funktioniert lasse ich das erst mal so stehen... kann man den genannten Loesungsansatz ohne Bedenken machen.. also ohne ins KeyHelp Gefuege damit einzugreifen?
These warnings indicate that files inside Postfix's chroot environment (`/var/spool/postfix/`) differ from their system counterparts. Here's what they mean:
1. **libnss_systemd.so.2 mismatch**
- The library inside `/var/spool/postfix/lib/...` differs from the system version.
- This could be due to a package update that didn't sync the chrooted files.
- Solution: Try updating the Postfix chroot environment:
```bash
cp -a /lib/x86_64-linux-gnu/libnss_systemd.so.2 /var/spool/postfix/lib/x86_64-linux-gnu/
2. **/etc/hosts mismatch**
- The `/var/spool/postfix/etc/hosts` file is out of sync with the system `/etc/hosts`.
- This can cause hostname resolution issues for Postfix.
- Solution: Sync the file manually:
```bash
cp -a /etc/hosts /var/spool/postfix/etc/
These warnings are not necessarily critical but should be addressed to ensure proper functionality.
Post by Fezzi »
So, ich hatte gerade mal Zeit den vorher genannten Loesungs Ansatz auf meinem Test System aus zu probieren...
Funkt einwandfrei... die Warnungen sind weg....
