SPF, DMARC  [SOLVED]
fatontonni123
SPF, DMARC  [SOLVED]
Post by fatontonni123 »
Where can I find SPF, DMARC dns Code in my Panel..
Can you help my..
Re: SPF, DMARC
in the DNS Zone Editor.
fatontonni123
Re: SPF, DMARC
Thanks. I use Dns but again Email dont work.. After send Any email in my Email dont sent can you help my..
I'm sorry to have to inform you that your message could not
be delivered to one or more recipients. It's attached below.
For further assistance, please send mail to postmaster.
If you do so, please include this problem report. You can
delete your own text from the attached returned message.
The mail system
Re: SPF, DMARC
Please give some more information ...
Is your server the nameserver for your domain(s) or is the nameserver of your domain hosters Nameserver still authoritative?
What records did you set to which values in the DNS-Editor or at your domain hoster?
How did you send the mails, which SMTP-Server did you specify? Try to use your servername here.
Is there a reverse DNS value set for your IP and does it match your servers name?
Is there more detail in the non delivery mail, e.g. a status code?
It's rather difficult to help if all we know is, that the mails cannot be delivered. ;)
fatontonni123
Re: SPF, DMARC
Now its okay but all email I'll take it to the spam folder. What the problem ?
Re: SPF, DMARC
Post by Fezzi »
Use this page and you might learn what your problem is.
https://www.learndmarc.com/
Without any detail information of your side it is impossible to help you.
