In version 25.1, the option to include domains in a user account has been removed.  [SOLVED]
kurgans
Post by kurgans »
Good morning,
Sorry for my English, I only speak Spanish.
I have set up a new panel on my VPS and I have seen that the new version has been released and is pending update today.
I notice that when logging in as a user with unlimited resources on the system, they cannot add domains because the entry to include the name does not appear.
They can only add a domain in the administrator by assigning this domain to a user as the owner.
Thank you all.
omexlu
Re: In version 25.1, the option to include domains in a user account has been removed.
Post by omexlu »
I can confirm this, there is a Javascript error in the console:
Uncaught ReferenceError: CodeMirror is not defined
    at initCodemirror (functions.js?v=6cad396cdfc7a2608c36fd32f70ca405160c4c86:867:9)
    at page_domain_edit.js?v=6cad396cdfc7a2608c36fd32f70ca405160c4c86:93:28
As a workaround:
give the permission to have 1000 Domains to the user.
Then try again.
omexlu
Post by omexlu »
That doesn't change anything, just tested in the demo, Javascript error is still there and still doesn't work :)
kurgans
Post by kurgans »
Tobi wrote: Fri 20. Jun 2025, 11:31 As a workaround:
Then try again.
Good morning,
No, that's not right. The user account already has unlimited status and it's not working. It's not a resource allocation issue.
It's a problem, as my colleague said, that the part of the form for entering the domain name isn't loading.
I also tried entering 1000 as you suggested, and as I thought, the system does not respond... part of the form is missing.
S2 -
Post by Fezzi »
The same here,
I updated on a test system to 25.1 and the field to enter a domain name is not loading (doesn't show).
Changing the permission for a user from 5 to 1000 or unlimited doesn't change it.
omexlu
Post by omexlu »
Lets wait, will be patched soon with the genial new patch system :)
Nothing big just a little javascript issue.
Re: In version 25.1, the option to include domains in a user account has been removed.  [SOLVED]
Thank you for reporting.
What a nice opportunity to test out the new Patch Manager :).
The patch is now live. Head over to 'Configuration' -> 'Patch Manager' and install it. As it is a JavaScript issue, browser cache clearing is likely necessary.
I have also updated the new KeyHelp version (Build 3433) which does not need this patch.
Post by Fezzi »
Works smooth like silk... ;)
Thx Alex...
omexlu
Post by omexlu »
Is there a notification on the dashboard if a new patch is available? (Not at home right now)
kurgans
Post by kurgans »
Good morning,
Sorry for my English, I only speak Spanish...
OK...
The patching system has worked very well.
Thank you,
S2 -
