HTTP 500 and not an error message in domain name creation
bytefly
Post by bytefly »
(Problems not related to KeyHelp belong in the Offtopic forum)
Server operating system + version: Debian 13
Server virtualization technology used: Qemu / KVM
KeyHelp version + build number: 25.2 (Build 3483)
Problem description / error messages: When I try to create a really long domain, it just throws HTTP 500. Max length of domain name before the dot is 63. The issue is the missing error message.
Steps to reproduce: Try to create a really long domain name, for example: "asdadsdasgdsjfghahgfdjkjassdadsdasdasdadjjjjjjjsdasasdadhdasaaaajjjhhhhhhhjad.hu"
Thank you!
blickgerecht
Re: HTTP 500 and not an error message in domain name creation
Post by blickgerecht »
I’m not 100% sure, but this might not be a bug in KeyHelp itself.
Domain names have some strict limits defined by DNS:
- Each label (the part between dots) can be at most 63 characters.
- The full domain can be at most 253 characters.
In your example, the first label seems to exceed that 63-character limit, so the domain would be invalid anyway. That could explain why KeyHelp rejects it.
Grüße
Roland
blickgerecht wrote: Fri 5. Sep 2025, 09:56 I’m not 100% sure, but this might not be a bug in KeyHelp itself.
As far as I can tell, it sounds like there might be a problem here. If I'm interpreting the issue description correctly, the panel is ignoring the 63-character limit, not throwing an error, and creating overly long domains in the panel (and in the DNS server, if it's being used).
@bytefly:
The developers will definitely look into this, thanks for the report!
Thank you for the report!
This is an issue with PHP 8.4 and only occur on Debian 13.
https://www.php.net/manual/zh/migration ... hanges.php
The idn_to_ascii() and idn_to_utf8() functions now always throw ValueErrors if the domain name is empty or too long.
I will fix it with the upcoming release of the next KeyHelp version.
