500 error on keyhelp panel only  [SOLVED]
curiousclumsy
Post by curiousclumsy »
I have updated from Ubuntu 20 to 22 then 24.
All websites are loading just fine.
What I have tried and still didn't resolve the issue:
- using KeyHelp toolbox and choosing Rewrite KeyHelp configuration
- using KeyHelp toolbox and choosing all maintenance tasks
- checked all logs in /var/log/apache2/
- checked all /var/log/php* fpm logs
Is there a way to reinstall keyhelp without losing any data?
Thanks
Re: 500 error on keyhelp panel only
please have a look into /var/log/keyhelp/php-error.log.
curiousclumsy
Alexander wrote: Fri 12. Sep 2025, 12:41 Hello,
thanks for the quick reply, in /var/log/keyhelp/php-error.log I see:
[12-Sep-2025 08:16:07 UTC] PHP Warning: file_put_contents(/etc/php/8.2/fpm/keyhelp_pool/website1.conf): Failed to open stream: No such file or directory in /home/keyhelp/www/keyhelp/core/Webserver/PhpFpm/PhpFpmPoolConfig.php on line 252
[12-Sep-2025 08:16:07 UTC] PHP Warning: file_put_contents(/etc/php/8.2/fpm/keyhelp_pool/website2.conf): Failed to open stream: No such file or directory in /home/keyhelp/www/keyhelp/core/Webserver/PhpFpm/PhpFpmPoolConfig.php on line 252
[12-Sep-2025 08:16:07 UTC] PHP Warning: file_put_contents(/etc/php/8.2/fpm/keyhelp_pool/website3.conf): Failed to open stream: No such file or directory in /home/keyhelp/www/keyhelp/core/Webserver/PhpFpm/PhpFpmPoolConfig.php on line 252
anywhere else I can check?
thanks
some more information
● php8.2-fpm.service - The PHP 8.2 FastCGI Process Manager
     Loaded: loaded (/usr/lib/systemd/system/php8.2-fpm.service; enabled; preset: enabled)
     Active: active (running) since Fri 2025-09-12 12:34:03 BST; 2min 13s ago
       Docs: man:php-fpm8.2(8)
    Process: 58773 ExecStartPost=/usr/lib/php/php-fpm-socket-helper install /run/php/php-fpm.sock /etc/php/8.2/fpm/pool.d/www.conf 82 (code=exited, status=0/SUCCESS)
    Process: 59099 ExecReload=/bin/kill -USR2 $MAINPID (code=exited, status=0/SUCCESS)
   Main PID: 58771 (php-fpm8.2)
     Status: "Processes active: 0, idle: 1, Requests: 72, slow: 0, Traffic: 0.80req/sec"
      Tasks: 2 (limit: 57814)
     Memory: 9.6M (peak: 13.3M)
        CPU: 336ms
     CGroup: /system.slice/php8.2-fpm.service
             ├─58771 "php-fpm: master process (/etc/php/8.2/fpm/php-fpm.conf)"
             └─59340 "php-fpm: pool keyhelp"
Sep 12 12:34:03 server1.xxxxxxxx.net systemd[1]: Starting php8.2-fpm.service - The PHP 8.2 FastCGI Process Manager...
Sep 12 12:34:03 server1.xxxxxxxx.net php-fpm8.2[58771]: [12-Sep-2025 12:34:03] WARNING: Nothing matches the include pattern '/etc/php/8.2/fpm/keyhelp_pool/*.conf' from />
Sep 12 12:34:03 server1.xxxxxxxx.net systemd[1]: Started php8.2-fpm.service - The PHP 8.2 FastCGI Process Manager.
Sep 12 12:34:28 server1.xxxxxxxx.net systemd[1]: Reloading php8.2-fpm.service - The PHP 8.2 FastCGI Process Manager...
Sep 12 12:34:28 server1.xxxxxxxx.net systemd[1]: Reloaded php8.2-fpm.service - The PHP 8.2 FastCGI Process Manager.
Sep 12 12:34:28 server1.xxxxxxxx.net php-fpm8.2[58771]: [12-Sep-2025 12:34:28] WARNING: Nothing matches the include pattern '/etc/php/8.2/fpm/keyhelp_pool/*.conf' from />
Sep 12 12:34:28 server1.xxxxxxxx.net php-fpm8.2[58771]: [12-Sep-2025 12:34:28] NOTICE: using inherited socket fd=8, "/run/php/keyhelp_keyhelp.socket"
Sep 12 12:34:42 server1.xxxxxxxx.net systemd[1]: Reloading php8.2-fpm.service - The PHP 8.2 FastCGI Process Manager...
Sep 12 12:34:42 server1.xxxxxxxx.net systemd[1]: Reloaded php8.2-fpm.service - The PHP 8.2 FastCGI Process Manager.
Sep 12 12:34:42 server1.xxxxxxxx.net php-fpm8.2[58771]: [12-Sep-2025 12:34:42] NOTICE: using inherited socket fd=8, "/run/php/keyhelp_keyhelp.socket"
curiousclumsy
just to add that my php cli is 8.2, not sure that makes any difference
php -v
PHP 8.2.29 (cli) (built: Jul 3 2025 13:08:18) (NTS)
Copyright (c) The PHP Group
Zend Engine v4.2.29, Copyright (c) Zend Technologies
with the ionCube PHP Loader v14.4.1, Copyright (c) 2002-2025, by ionCube Ltd.
with Zend OPcache v8.2.29, Copyright (c), by Zend Technologies
curiousclumsy wrote: Fri 12. Sep 2025, 13:50 just to add that my php cli is 8.2, not sure that makes any difference
php -v
If you are already on Ubuntu 24, this is not the correct PHP Version for your operating system. On Ubuntu 24 there should be PHP 8.3.6
I assume that all steps in the upgrade guide have been followed completely (https://www.keyweb.de/en/keyhelp/develo ... -ubuntu-24).
Uninstall all PHP versions, than install the correct one again.
apt-get install -y php php-curl php-gd imagemagick php-imagick php-mail-mime php-net-sieve php-pspell php-net-socket php-auth-sasl php-intl php-net-smtp php-zip php-bcmath php-gmp php-soap php-mbstring php-mysql php-readline php-redis
(cross reference viewtopic.php?t=14120)
Or send me the SSH login credentials to your server via PM and i'll have a look.
curiousclumsy
Hi Alexander, I have now removed all php versions.
root@server1:/etc# which php8.1
root@server1:/etc# which php8.2
root@server1:/etc# which php8.3
/usr/bin/php8.3
root@server1:/etc# which php8.4
Then the server1.xxxxxx.com page was showing a 503 error. I then regenerated the config using toolbox and the same 500 error shows.
Is there any other log I can look at?
Many thanks
PS: thanks for the ssh offer, unfortunately our IT team has blocked the ssh port from being accessed from outside our network.
I do not see the package php-fpm in Alexander's list.
Install this package, too.
Then it should work.
curiousclumsy
hi Florian, I included that myself before running the command.
Still no luck, sorry about that.
Is there a log for apache perhaps?
I might have to format and start from scratch.
Thanks!
root@server1:/etc# sudo apt-get install php php-cli php-fpm php-curl php-gd imagemagick php-imagick php-mail-mime php-net-sieve php-pspell php-net-socket php-auth-sasl php-intl php-net-smtp php-zip php-bcmath php-gmp php-soap php-mbstring php-mysql php-readline php-redis php-fpm
Reading package lists... Done
Building dependency tree... Done
php is already the newest version (2:8.3+93ubuntu2).
php-cli is already the newest version (2:8.3+93ubuntu2).
php-fpm is already the newest version (2:8.3+93ubuntu2).
php-curl is already the newest version (2:8.3+93ubuntu2).
php-gd is already the newest version (2:8.3+93ubuntu2).
imagemagick is already the newest version (8:6.9.12.98+dfsg1-5.2build2).
php-imagick is already the newest version (3.7.0-4ubuntu3).
php-mail-mime is already the newest version (1.10.11-1).
php-net-sieve is already the newest version (1.4.6-1).
php-pspell is already the newest version (2:8.3+93ubuntu2).
php-net-socket is already the newest version (1.2.2-2).
php-auth-sasl is already the newest version (1.2.0-1).
php-intl is already the newest version (2:8.3+93ubuntu2).
php-net-smtp is already the newest version (1.11.1-1).
php-zip is already the newest version (2:8.3+93ubuntu2).
php-bcmath is already the newest version (2:8.3+93ubuntu2).
php-gmp is already the newest version (2:8.3+93ubuntu2).
php-soap is already the newest version (2:8.3+93ubuntu2).
php-mbstring is already the newest version (2:8.3+93ubuntu2).
php-mysql is already the newest version (2:8.3+93ubuntu2).
php-readline is already the newest version (2:8.3+93ubuntu2).
php-redis is already the newest version (5.3.7+4.3.0-3ubuntu1).
curiousclumsy
cat /var/log/apache2/*.log
[Fri Sep 12 00:00:01.231084 2025] [ssl:error] [pid 696239:tid 140615250999168] AH02604: Unable to configure certificate webmail:443:0 for stapling
[Fri Sep 12 00:00:01.237883 2025] [mpm_event:notice] [pid 696239:tid 140615250999168] AH00489: Apache/2.4.52 (Ubuntu) mod_fcgid/2.3.9 OpenSSL/3.0.2 configured -- resuming normal operations
[Fri Sep 12 00:00:01.237919 2025] [core:notice] [pid 696239:tid 140615250999168] AH00094: Command line: '/usr/sbin/apache2'
apache logs if these are the only one, doesnt show much
Provide the logins to SSh (root access) via PM. I will have a look
curiousclumsy
Re: 500 error on keyhelp panel only  [SOLVED]
Hi, I have resolved this by making a backup of keyhelp database, the run the install script and restore the keyhelp database, all was good.
Thank you!
