I recently started using Keyhelp Pro. I really like it so far, it works exactly as it should. However, I have two questions:
Question 1: When I try to upload a folder outside the WWW directory, it doesn’t work. I get the error message: Failed to upload file xxxxx.zip. Is it not possible to upload files outside the WWW directory, or is there a way to make this work? If so, how does it work?
Question 2: If it is possible, what would be the correct full path to the uploaded folder outside my WWW directory for normal users (not root)? For example, is it:
/home/user/<username>/xxxfolder
or / <username>/xxxfolder
I would really appreciate a clear answer. Thanks again for your help.
Best regards,
Marcel
