Error Backup - Failed to prepare database [SOLVED]
I am attaching the information you requested. I see that the other thread is closed and I cannot follow it.
The system is Debian 12, which has just been installed, and everything is default when we install the panel. Server version: 10.11.14-MariaDB-0+deb12u2 Debian 12
The panel version is the latest, as it has only been installed a few days ago.
Keyhelp - Version 25.2 (Build 3483)
@Alexander, regarding what you mentioned, I also checked the tables and there is no difference between them and other tables with the same views. I am attaching a fragment in a txt file so as not to make the thread too long.
And regarding the warnings, it does not indicate anything.
SHOW WARNINGS;
Empty set (0.000 sec)
A script I created via ssh performs the backups without any problems and without any modifiers.
echo $DB
mysqldump -u root -p$MYSQL_PASSWORD $DB > “$BACKUP_DIR/base-pre-$DATE.sql”
Thank you again for your interest.
- Attachments
- status.txt
- (9.9 KiB) Downloaded 100 times
Re: Error Backup - Failed to prepare database
can you perform the mysqldump again, but this time use the following command (i added 3 additional parameters):
mysqldump -u root -p$MYSQL_PASSWORD --routines --skip-lock-tables --databases $DB > “$BACKUP_DIR/base-pre-$DATE.sql”Alexander Mahr
If those are the default modifiers I have in the SSH script and they work perfectly with the SQL dumps,
728330234 Oct 15 14:43 db-pre-15-10-2025.sql
I removed the modifiers to post them on the forum so that it would be a command without any parameters.
But they both work the same with or without modifier parameters.
728329930 Oct 15 14:47 basesin-pre-15-10-2025.sql
Thank you for your interest and help.
If so, please activate support access ("Configuration -> Support Access") and send me the server IP address (and your SSH port, if it is not 22)
You have the IP address in a private message.
Thank you for your interest.
Re: Error Backup - Failed to prepare database [SOLVED]
The issue is now fixed on kurgans system and will be fixed for all of you with the upcoming update.
I was able to make two improvements from this issue - thank you very much for sharing it and letting me take a look at your server.
And even better... if it's something you can share with everyone in an improvement to the panel.
S2
