Problem  [SOLVED]
fatontonni123
Problem  [SOLVED]
Post by fatontonni123 »
Helloo.
I have problem With SMTP and Imap port in my vps.. After i install wordpres The smtp port dont Work i need this for email Contact Form can ypu have any methot to fixe this.
Tobi7889
Re: Problem
Post by Tobi7889 »
It would be helpful if you could also show us how you configured it.
Liebe Grüße
Tobias
