Quotaon
fatontonni123
Quotaon
Post by fatontonni123 »
I have problem with quitaon
quotaon: Your kernel probably supports ext4 quota feature but you are using rnal quota files. Please switch your filesystem to use ext4 quota feature asernal quota files on ext4 are deprecated. You can enable the feature by unmong the file system and running 'tune2fs -O quota <device>'.
quotaon: using //aquota.group on /dev/sda2 [/]: Device or resource busy
quotaon: using //aquota.user on /dev/sda2 [/]: Device or resource busy
Re: Quotaon
Moderator's note:
The post template that is provided when creating a new thread in the "Bugs and Issues" forum section exists for a reason.
Therefore, I would like to ask you to create a new thread and fill in the post template with the required information. This information will then help the community to provide you with targeted assistance with your problem.
Thank you.
Thread closed.
