Problem with quotaon
fatontonni123
Post by fatontonni123 »
quotaon -a
quotaon: Your kernel probably supports ext4 quota feature but you are using external quota files. Please switch your filesystem to use ext4 quota feature as external quota files on ext4 are deprecated. You can enable the feature by unmounting the file system and running 'tune2fs -O quota <device>'.
quotaon: cannot find //quota.group on /dev/sda2 [/]
quotaon: cannot find //quota.user on /dev/sda2 [/]
Re: Problem with quotaon
Moderator's note:
The post template that is provided when creating a new thread in the "Bugs and Issues" forum section exists for a reason.
Therefore, I would like to ask you to create a new thread and fill in the post template with the required information. This information will then help the community to provide you with targeted assistance with your problem.
Thank you.
Thread closed.
