Problem with quotaon
fatontonni123
Post by fatontonni123 »
(I think so.)
( Debian 13.2 )
(KVM)
(25.2 (Build 3483))
quotaon -a
quotaon: Your kernel probably supports ext4 quota feature but you are using external quota files. Please switch your filesystem to use ext4 quota feature as external quota files on ext4 are deprecated. You can enable the feature by unmounting the file system and running 'tune2fs -O quota <device>'.
quotaon: cannot find //quota.group on /dev/sda2 [/]
quotaon: cannot find //quota.user on /dev/sda2 [/]
Re: Problem with quotaon
fatontonni123
Tobi wrote: Sun 23. Nov 2025, 14:23 Your kernel probably supports ext4 quota feature but you are using external quota files.
tune2fs -O quota /dev/sda2
tune2fs 1.47.2 (1-Jan-2025)
The quota feature may only be changed when the filesystem is unmounted and not in use.
not work
Please read and understand your error messages:
To fix this, unmount the partition first and run:
Then remount with quota options and activate quotas using:
quotaon -vaugP
This enables ext4's native quota feature and resolves the issue. If the root partition is involved, use rescue mode to apply changes.
