About A few Answer
saviorhost
About A few Answer
Post by saviorhost »
Hello everyone;
Gemini was recommended. After researching it, I found it to be quite stable. However, I have a few questions. I would be very grateful if you could answer them.
1. How is Nginx support? Can site speeds be increased like LiteSpeed? Does it support http3/quic? Are there configurations suitable for every CMS?
2. What is the security level? Does it support Maldet+Clamav?
3. How is PHP-FPM support? How many processes does it support?
4. Does it support caching like Varnish?
5. Does the client have the option to back up and restore themselves? Does it support JetBackup?
6. Will there be automatic migration systems from systems like cPanel and CWP?
Thank you in advance. Have a good day.
Re: About A few Answer
- There is no nginx support now. KeyHelp ships with Apache web server.
- http3/quic is currently not really supported by Apache.
- Depending on the traffic, you may want to adjust some settings within KeyHelp - but this highly depends on your use case and the available hardware. For regular hosting, the default settings should be fine.
- Can you elaborate, what do you mean exactly with "what is the security level?" - i would say 9/10 :lol:
- ClamAV is installed as part of KeyHelp
- Again, what do you mean with "How is PHP-FPM support" - i would say it is fine. You will get multiple PHP-Interpreter and are able to adjust the settings on a user basis."How many processes does it support?" - How many can your hardware handle?
You can configure caching alongside KeyHelp. It is not installed out-of-the-box.
KeyHelp comes with an own backup solution, based on Resic as a core component, supported by Rclone to support a large amount of remote storages.
For now, we officially only support migration from Plesk and KeyHelp to KeyHelp via KeyHelp Pro (https://www.keyweb.de/en/keyhelp/keyhel ... ement-tool)
There is also a community provided migration script from i-MSCP to KeyHelp as well viewtopic.php?t=9665
To get to know KeyHelp a bit better, you may want to try out the demo at https://demo.keyhelp.eu
saviorhost
Alexander wrote: Mon 12. Jan 2026, 15:41
Thank you for your feedback.
I use CentOS Web Panel and plan to change it. I'm a hosting company. I'm looking for alternatives because I find cPanel and Plesk prices exorbitant and believe they've taken over the industry.
I'm concerned about Apache. There's a huge difference between Apache and LiteSpeed. High-traffic sites can achieve higher performance using fewer resources. With Nginx, good configuration can achieve performance close to LiteSpeed.
In terms of security, CWP has features like MOD Security, Snuffleupagus, a grid system, and separate resource allocation for each site.
I also aim to integrate Maldet and Clamav.
I strive to provide my clients with the best service at the most competitive prices.
DiamantTh
Post by DiamantTh »
Hi Alexander,
thanks for the clarification (Apache-only, no nginx, hence no HTTP/3/QUIC).
I’m currently re-evaluating my hosting stack/panel options, and native HTTP/3/QUIC support has become a hard requirement for me (without a CDN/proxy in front).
Given that Apache won’t realistically provide this: is nginx (as an optional frontend / reverse proxy) still on the roadmap in general?
No ETA needed — just a direction (“planned”, “not planned”, “blocked by X”) would already help a lot to decide whether to wait or to look elsewhere.
Thanks!
Nginx is still on the "planned" list.
