modsecurity phpmyadmin error
- saviorhost
Forbidden
You don't have permission to access this resource.
Re: modsecurity phpmyadmin error
- saviorhost
Wouldn't server security be a problem? Many different websites are hosted there.
- saviorhost
In fact nobody uses ModSecurity and everybody is fine.
- saviorhost
I'm a hosting company. Even now, I host hundreds of websites. That's why I need to provide protection.
In this respect, @Tobi's advice is correct - in such an environment, mod_security cannot be used effectively without encountering various minor and major problems
If it prevents SQL files from being uploaded to PHPMyAdmin, it ultimately does exactly what it's intended to do. If you don't want that, you have to define an appropriate exception. But as I said: especially with customers it's practically impossible, they just see something that doesn't work.
The issue could be fixed by targeted whitelisting instead of full disablement.
Check ModSecurity logs for the blocking rule ID, then whitelist it or the /phpMyAdmin/ path in the config (/etc/modsecurity.d/). This should preserves overall security.
Do you use KeyHelp Pro?
Putting customers in jailroot is probably the best security you can get.
- saviorhost
Yes, I use KeyHelp Pro. How exactly do I install jailroot? Is there an article or topic about it?
- "User Administration -> Add or edit a client -> Permissions -> Enable SSH + Restricted SSH environment"
Further configuration can be done here:
- "Configuration -> Restricted SSH Environment"
- saviorhost
Dear Aleksander;
Yes, I saw that. What do I need to write there? Is there any document related to it?
Where exactly?
- saviorhost
KeyHelp will try its best to also copy required lib files, required to run the binary but sometimes some additional data to run them is needed. Therefor you have the second input area, where you can define additional paths, which get copied 1:1 into the restricted SSH environment.
You do not need to fill out the input fields at all, you can try the default environment first. If you can not execute a command you would like to make available than you can try to fill out the input fields with the corresponding paths.
