Fehler bei Distupgrade von Debian 12 auf 13
MadDogg
Post by MadDogg »
(z.B. Ja / Nein (Probleme ohne KeyHelp-Bezug gehören ins Offtopic-Forum))
Nein
(z.B. Ubuntu 24.04)
Debian 12.13 (64-bit)
(z.B. 26.0 - Build 3582)
25.3 (Build 3565)
Ich möchte ein Dist Upgrade auf Debian 13 laut Keyhelp Anleitung durchführen.
Folgende Fehlermeldung erscheint mir.
root@web:~# wget --no-check-certificate https://install.keyhelp.de/scripts/upgra        de_operating_system.sh -O upgrade_operating_system.sh && bash upgrade_operating_        system.sh
--2026-04-07 23:09:03--  https://install.keyhelp.de/scripts/upgrade_operating_sy        stem.sh
Resolving install.keyhelp.de (install.keyhelp.de)... 62.141.56.232, 2001:1b60:2:        11:913:101:be57:cafe
Connecting to install.keyhelp.de (install.keyhelp.de)|62.141.56.232|:443... conn        ected.
HTTP request sent, awaiting response... 200 OK
Length: 10340 (10K) [text/x-sh]
Saving to: ‘upgrade_operating_system.sh’
upgrade_operating_s 100%[===================>]  10.10K  --.-KB/s    in 0s
2026-04-07 23:09:03 (78.5 MB/s) - ‘upgrade_operating_system.sh’ saved [10340/103        40]
You are about to upgrade the operating system of your KeyHelp server.
Running system checks...
Run upgrade script...
Fatal error: Uncaught Error: Class "Database\DBConnection" not found in /root/ke        yhelp_debian_upgrade_12_to_13.php:84
Stack trace:
#0 {main}
  thrown in /root/keyhelp_debian_upgrade_12_to_13.php on line 84
Nur ein Temspeak3 Server läuft nebenbei, ansonsten alles Keyhelp Standard.
Für angehende Antworten bedanke ich mich schonmal im Vorfeld.
Viele Grüße
Pierre
Re: Fehler bei Distupgrade von Debian 12 auf 13
Was sagt php -v?
MadDogg
Post by MadDogg »
root@web:~# php -v
PHP 8.2.30 (cli) (built: Feb 28 2026 07:07:34) (NTS)
Copyright (c) The PHP Group
Zend Engine v4.2.30, Copyright (c) Zend Technologies
    with the ionCube PHP Loader v14.4.1, Copyright (c) 2002-2025, by ionCube Ltd.
    with SourceGuardian v16.0.2, Copyright (c) 2000-2025, by SourceGuardian Ltd.
    with Zend OPcache v8.2.30, Copyright (c), by Zend Technologies
OK, das passt. Manchmal sind Sury Installationen schuld an solchen Problemen.
Da der code von KeyHelp leider scrambled ist wirst Du bis morgen auf den Support warten müssen :-(
MadDogg
Post by MadDogg »
Danke trotzdem, ansonsten funktioniert alles Tadellos.
Benutze Keyhelp Pro, aber das wird wahrscheinlich auch keinen unterschied machen.
Schönen Abend noch :)
Aktualisiere zunächst einmal KeyHelp auf 26.0 (ist wahrscheinlich heute Nacht bei dir automatisch passiert) danach läuft auch das Dist-Upgrade-Script.
