Multiple PHP versions in KeyHelp 18.1.1  [SOLVED]
sburina
Post by sburina »
Hello!
I'm evaluating KeyHelp 18.1.1 on Ubuntu 18.04, and can't find a documented way to install multiple PHP versions.
I'm looking at Server Settings -> PHP interpreter, but there's a text "- No entries available -" under both "Installed PHP interpreters" and "Additional available PHP interpreters", so there's nothing to choose from. I've tried installing additional PHP version using Ondrej PPA, but it didn't show up in the KeyHelp interface.
Can anyone please advise?
Thank you!
Re: Multiple PHP versions in KeyHelp 18.1.1
the additional PHP interpreters for Ubuntu 18 are not ready yet - expect them to be available in the couse of the week.
Background: Till now, the PHP Versions before 7.0 are not working because of a segfault when executing PHP scripts, no matter what I try. So I can not promise to make them work with Ubuntu 18 at all / soon. If you really depend on these versions, it may be better to use Debian 9 for now.
As a small notification: The additional PHP interpreters are now ready.
Also all other PHP interpreters have been updated.
sburina
Post by sburina »
Alexander wrote: Mon 25. Jun 2018, 14:17 As a small notification: The additional PHP interpreters are now ready.
Hello, Alexander!
Yes, they are all visible now. Thank you for your effort, keep up the good work! :)
