Mail & Mysql Problem  [GELÖST]
Fiesi
Post by Fiesi »
Ich hab mich schon seit nen paar Tagen gewundert wieso auf meine Mail keine Mails mehr ankommen :D
habe heute mal im mail.warn geschaut und dort viel mir folgendes auf:
Jul 27 13:56:32 host postfix/trivial-rewrite[26428]: warning: connect to mysql server 127.0.0.1: Access denied for user 'keyhelp'@'127.0.0.1' (using password: YES)
Jul 27 13:56:32 host postfix/trivial-rewrite[26428]: warning: virtual_alias_domains: mysql:/etc/postfix/mysql-virtual-alias-maps.cf: table lookup problem
Jul 27 13:56:32 host postfix/trivial-rewrite[26428]: warning: virtual_alias_domains lookup failure
Jul 22 06:46:32 host postfix/cleanup[7349]: warning: 85D7C220029A: virtual_alias_maps map lookup problem for support@xxx.net -- message not accepted, try again later
Jul 22 06:47:32 host postfix/cleanup[7349]: warning: connect to mysql server 127.0.0.1: Access denied for user 'keyhelp'@'127.0.0.1' (using password: YES)
Jul 22 06:47:32 host postfix/cleanup[7349]: warning: mysql:/etc/postfix/mysql-virtual-alias-maps.cf lookup error for "support@xxx.net"
Jul 22 06:47:32 host postfix/cleanup[7349]: warning: 94B8C22004D7: virtual_alias_maps map lookup problem for support@xxx.net -- message not accepted, try again later
Jul 22 06:48:32 host postfix/cleanup[7349]: warning: mysql:/etc/postfix/mysql-virtual-alias-maps.cf lookup error for "support@xxx.net"
Jul 22 06:48:32 host postfix/cleanup[7349]: warning: A3AF422004D7: virtual_alias_maps map lookup problem for support@xxx.net -- message not accepted, try again later
Jul 22 06:49:32 host postfix/cleanup[7349]: warning: connect to mysql server 127.0.0.1: Access denied for user 'keyhelp'@'127.0.0.1' (using password: YES)
Jul 22 06:49:32 host postfix/cleanup[7349]: warning: mysql:/etc/postfix/mysql-virtual-alias-maps.cf lookup error for "support@xxx.net"
Jul 22 06:49:32 host postfix/cleanup[7349]: warning: B2A3722004D7: virtual_alias_maps map lookup problem for support@xxx.net -- message not accepted, try again later
Jul 22 06:50:32 host postfix/cleanup[7349]: warning: mysql:/etc/postfix/mysql-virtual-alias-maps.cf lookup error for "support@xxx.net"
es scheint so, als ob keyhelp teilweise kein MYSQL zugriff mehr hat?
Es wurde nichts neu installiert außer eventuelle updates die Keyhelp ja glaub ich selber per Cron macht...
Daniel
Re: Mail & Mysql Problem
Post by Daniel »
versuche bitte einmal dich mit dem Passwort und dem mysql-user: keyhelp aus
direkt über SSH anzumelden.
Der Befehl ist:
~$ mysql -ukeyhelp -p
Wenn dies nicht möglich ist, dann stimmt das Passwort nicht mit dem Tatsächlich gesetzten überein.
Sofern die generelle Funktion von Keyhelp selbst nicht beeinträchtigt ist, dann jenes Passwort aus
/etc/keyhelp/config/config.json
in die
/etc/postfix/mysql-virtual-*.cf
eingetragen werden. Postfix muss im Anschluss neugestartet werden.
Daniel Marckardt
Fiesi
Post by Fiesi »
Das hat Funktioniert:
root@host ~ # mysql -ukeyhelp -p
Enter password:
Welcome to the MariaDB monitor. Commands end with ; or \g.
Your MariaDB connection id is 185230
Server version: 10.1.26-MariaDB-0+deb9u1 Debian 9.1
Copyright (c) 2000, 2017, Oracle, MariaDB Corporation Ab and others.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
MariaDB [(none)]>
PW's sind gleich in beiden Datein
Fiesi
Re: Mail & Mysql Problem  [GELÖST]
Post by Fiesi »
Fehler gefunden.
Hatte in der .conf
skip-name-resolve
mit drin, das mochte er wohl nicht.
Ich bin auch drauf reingefallen :-(
