Phpmyadmin import filesize  [SOLVED]
info@eurhosting.net
Post by info@eurhosting.net »
Hello
How to increase the max filesize in phpmyadmin of importing db?
At the moment if I'm not wrong is 64mega
Stop stop stop
If hosting is not your main focus, I can be of help to mantain your servers
info@eurhosting.net
Re: Phpmyadmin import filesize
Could be the
upload_max_filesize
in the php.ini? That need a server reboot?
Stop stop stop
Daniel
Post by Daniel »
you need to change the "upload_max_filesizie"
/etc/php5/fpm/pool.d/keyhelp.conf
And perform a restart via:
/etc/init.d/apache2 restart; /etc/init.d/php-fpm restart
But its not recommended to import such large dumps through phpmyadmin. It should be proceed by the usage of the cli/ssh dump for less possible errors and better performance.
Daniel Marckardt
info@eurhosting.net
Re: Phpmyadmin import filesize [SOLVED]  [SOLVED]
Hello Daniel
Thank you very much for this useful hint.
I'm aware, but customer is not able to do it himselfe and doesn't want to be billed for the service so we agreed to allow him temporarily to enlarge the filesize for the upload.
Stop stop stop
info@eurhosting.net wrote: but customer is not able to do it himselfe and doesn't want to be billed for the service
I always recommend bigdump.
See: http://www.ozerov.de/bigdump/
You upload the file via FTP (no file upload limit ;) ) and the usage is pretty simple. This script even works with very large Imports.
Another possibility would be to import the file from shell
mysql -h localhost -u username --password=secret database < importfile.sql
