Suggestion  [SOLVED]
majorboobage
Suggestion
Post by majorboobage »
avscan.log
------ UPDATE VIRUS DATABASE -------
Start: 2018-08-16 06:41:01
End: 2018-08-16 06:41:01
Status: Failed
As we can see status Failed, but this is not correct (can confuse the user) because ClamAV already is up to date :)
Thu Aug 16 06:41:01 2018 -> --------------------------------------
Thu Aug 16 06:41:01 2018 -> ClamAV update process started at Thu Aug 16 06:41:01 2018
Thu Aug 16 06:41:01 2018 -> main.cvd is up to date (version: 58, sigs: 4566249, f-level: 60, builder: sigmgr)
Thu Aug 16 06:41:01 2018 -> daily.cvd is up to date (version: 24846, sigs: 2049688, f-level: 63, builder: neo)
Thu Aug 16 06:41:01 2018 -> bytecode.cvd is up to date (version: 327, sigs: 91, f-level: 63, builder: neo)
I propose to change it to for ex: ClamAV is up to date ;)
Thanks devs!
Re: Suggestion  [SOLVED]
Thanks and fixed!
(The return code of freshclam returns 0 or 1 in case of success/up to date database, i only checked for 0 until now...)
