ich habe einen V-Server mit Ubuntu 18.04 bei der Installation schlägt der Punkt Firewall fehl mit folgender Meldung:
Warning: file_put_contents(/etc/network/if-pre-up.d/keyhelp_load_rules): failed to open stream: No such file or directory in /home/keyhelp/www/keyhelp/core/pending/File.php on line 311
[Firewall (iptables)]
exec | mkdir -p -m 0700 /etc/keyhelp/iptables/
files | /home/keyhelp/www/keyhelp/install/config/common/iptables/ipv4_wan => /etc/keyhelp/iptables/startup_rules_ipv4
files | /home/keyhelp/www/keyhelp/install/config/common/iptables/ipv6_wan => /etc/keyhelp/iptables/startup_rules_ipv6
files | /home/keyhelp/www/keyhelp/install/config/common/iptables/keyhelp_load_rules => /etc/network/if-pre-up.d/keyhelp_load_rules
Could not save file "/etc/network/if-pre-up.d/keyhelp_load_rules"
!!! ERROR DETECTED !!!
[SKIPPED DUE PREVIOUS ERRORS] exec | chmod 0755 /etc/network/if-pre-up.d/keyhelp_load_rules
[SKIPPED DUE PREVIOUS ERRORS] db | UPDATE `keyhelp`.`firewall` SET `rules` = '{"INPUT":{"name":"INPUT","comment":"","rules":[{"is_disabled":false,"comment":"","action":"Bogus","params":[]},{"is_disabled":false,"comment":"","action":"Always","params":[]},{"is_disabled":false,"comment":"","action":"Banned","params":[]},{"is_disabled":false,"comment":"","action":"fail2ban","params":[]},{"is_disabled":false,"comment":"","action":"Allow","params":[]}],"policy":"ACCEPT"},"FORWARD":{"name":"FORWARD","comment":"","rules":[{"is_disabled":false,"comment":"","action":"Bogus","params":[]},{"is_disabled":false,"comment":"","action":"Always","params":[]},{"is_disabled":false,"comment":"","action":"Banned","params":[]},{"is_disabled":false,"comment":"","action":"Allow","params":[]}],"policy":"ACCEPT"},"OUTPUT":{"name":"OUTPUT","comment":"","rules":[],"policy":"ACCEPT"},"Allow":{"name":"Allow","comment":"","rules":[{"is_disabled":false,"comment":"","action":"Friend","params":[{"is_inverted":false,"name":"--protocol","value":"icmp"},{"is_inverted":false,"name":"--match","value":"icmp"},{"is_inverted":false,"name":"--icmp-type","value":"8"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"icmp"},{"is_inverted":false,"name":"--match","value":"icmp"},{"is_inverted":false,"name":"--match","value":"limit"},{"is_inverted":false,"name":"--icmp-type","value":"any"},{"is_inverted":false,"name":"--limit","value":"1\/sec"}]},{"is_disabled":false,"comment":"","action":"DROP","params":[{"is_inverted":false,"name":"--protocol","value":"icmp"},{"is_inverted":false,"name":"--match","value":"icmp"},{"is_inverted":false,"name":"--icmp-type","value":"any"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--in-interface","value":"lo"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"tcp"},{"is_inverted":false,"name":"--destination-port","value":"53"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"udp"},{"is_inverted":false,"name":"--match","value":"udp"},{"is_inverted":false,"name":"--destination-port","value":"53"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"tcp"},{"is_inverted":false,"name":"--destination-port","value":"20"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"tcp"},{"is_inverted":false,"name":"--destination-port","value":"21"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"multiport"},{"is_inverted":false,"name":"--destination-ports","value":"30000:30500"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"tcp"},{"is_inverted":false,"name":"--destination-port","value":"22"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"tcp"},{"is_inverted":false,"name":"--destination-port","value":"80"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"tcp"},{"is_inverted":false,"name":"--destination-port","value":"443"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"tcp"},{"is_inverted":false,"name":"--destination-port","value":"25"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"tcp"},{"is_inverted":false,"name":"--destination-port","value":"587"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"tcp"},{"is_inverted":false,"name":"--destination-port","value":"110"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"tcp"},{"is_inverted":false,"name":"--destination-port","value":"143"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"tcp"},{"is_inverted":false,"name":"--destination-port","value":"993"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"tcp"},{"is_inverted":false,"name":"--destination-port","value":"995"}]},{"is_disabled":false,"comment":"","action":"REJECT","params":[{"is_inverted":false,"name":"--reject-with","value":"icmp-port-unreachable"}]}]},"Always":{"name":"Always","comment":"","rules":[{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--in-interface","value":"lo"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--match","value":"state"},{"is_inverted":false,"name":"--state","value":"RELATED,ESTABLISHED"}]},{"is_disabled":false,"comment":"","action":"Friend","params":[]}]},"Banned":{"name":"Banned","comment":"","rules":[]},"Bogus":{"name":"Bogus","comment":"","rules":[{"is_disabled":false,"comment":"","action":"DROP","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"tcp"},{"is_inverted":false,"name":"--tcp-flags","value":"FIN,SYN FIN,SYN"}]},{"is_disabled":false,"comment":"","action":"DROP","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"tcp"},{"is_inverted":false,"name":"--tcp-flags","value":"SYN,RST SYN,RST"}]},{"is_disabled":false,"comment":"","action":"DROP","params":[{"is_inverted":false,"name":"--source","value":"169.254.0.0\/16"}]},{"is_disabled":false,"comment":"","action":"DROP","params":[{"is_inverted":false,"name":"--source","value":"172.16.0.0\/12"}]},{"is_disabled":false,"comment":"","action":"DROP","params":[{"is_inverted":false,"name":"--source","value":"192.0.2.0\/24"}]},{"is_disabled":false,"comment":"","action":"DROP","params":[{"is_inverted":false,"name":"--source","value":"192.168.0.0\/16"}]},{"is_disabled":false,"comment":"","action":"DROP","params":[{"is_inverted":false,"name":"--source","value":"10.0.0.0\/8"}]},{"is_disabled":false,"comment":"","action":"DROP","params":[{"is_inverted":false,"name":"--source","value":"127.0.0.0\/8"},{"is_inverted":true,"name":"--in-interface","value":"lo"}]}]},"Friend":{"name":"Friend","comment":"","rules":[{"is_disabled":false,"comment":"","action":"RETURN","params":[]}]},"fail2ban":{"name":"fail2ban","comment":"","rules":[]}}' WHERE `ip_version` = 'ipv4' AND `type` = 'current'
[SKIPPED DUE PREVIOUS ERRORS] db | UPDATE `keyhelp`.`firewall` SET `rules` = '{"INPUT":{"name":"INPUT","comment":"","rules":[{"is_disabled":false,"comment":"","action":"Bogus","params":[]},{"is_disabled":false,"comment":"","action":"Always","params":[]},{"is_disabled":false,"comment":"","action":"Banned","params":[]},{"is_disabled":false,"comment":"","action":"fail2ban","params":[]},{"is_disabled":false,"comment":"","action":"Allow","params":[]}],"policy":"ACCEPT"},"FORWARD":{"name":"FORWARD","comment":"","rules":[{"is_disabled":false,"comment":"","action":"Bogus","params":[]},{"is_disabled":false,"comment":"","action":"Always","params":[]},{"is_disabled":false,"comment":"","action":"Banned","params":[]},{"is_disabled":false,"comment":"","action":"Allow","params":[]}],"policy":"ACCEPT"},"OUTPUT":{"name":"OUTPUT","comment":"","rules":[],"policy":"ACCEPT"},"Allow":{"name":"Allow","comment":"","rules":[{"is_disabled":false,"comment":"","action":"Friend","params":[{"is_inverted":false,"name":"--protocol","value":"ipv6-icmp"},{"is_inverted":false,"name":"--match","value":"icmp6"},{"is_inverted":false,"name":"--icmpv6-type","value":"128"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"ipv6-icmp"},{"is_inverted":false,"name":"--match","value":"limit"},{"is_inverted":false,"name":"--limit","value":"1\/sec"}]},{"is_disabled":false,"comment":"","action":"DROP","params":[{"is_inverted":false,"name":"--protocol","value":"ipv6-icmp"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--in-interface","value":"lo"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"tcp"},{"is_inverted":false,"name":"--destination-port","value":"53"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"udp"},{"is_inverted":false,"name":"--match","value":"udp"},{"is_inverted":false,"name":"--destination-port","value":"53"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"tcp"},{"is_inverted":false,"name":"--destination-port","value":"20"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"tcp"},{"is_inverted":false,"name":"--destination-port","value":"21"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"multiport"},{"is_inverted":false,"name":"--destination-ports","value":"30000:30500"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"tcp"},{"is_inverted":false,"name":"--destination-port","value":"22"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"tcp"},{"is_inverted":false,"name":"--destination-port","value":"80"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"tcp"},{"is_inverted":false,"name":"--destination-port","value":"443"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"tcp"},{"is_inverted":false,"name":"--destination-port","value":"25"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"tcp"},{"is_inverted":false,"name":"--destination-port","value":"587"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"tcp"},{"is_inverted":false,"name":"--destination-port","value":"110"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"tcp"},{"is_inverted":false,"name":"--destination-port","value":"143"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"tcp"},{"is_inverted":false,"name":"--destination-port","value":"993"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"tcp"},{"is_inverted":false,"name":"--destination-port","value":"995"}]},{"is_disabled":false,"comment":"","action":"REJECT","params":[{"is_inverted":false,"name":"--reject-with","value":"icmp6-port-unreachable"}]}]},"Always":{"name":"Always","comment":"","rules":[{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--in-interface","value":"lo"}]},{"is_disabled":false,"comment":"","action":"ACCEPT","params":[{"is_inverted":false,"name":"--match","value":"state"},{"is_inverted":false,"name":"--state","value":"RELATED,ESTABLISHED"}]},{"is_disabled":false,"comment":"","action":"Friend","params":[]}]},"Banned":{"name":"Banned","comment":"","rules":[]},"Bogus":{"name":"Bogus","comment":"","rules":[{"is_disabled":false,"comment":"","action":"DROP","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"tcp"},{"is_inverted":false,"name":"--tcp-flags","value":"FIN,SYN FIN,SYN"}]},{"is_disabled":false,"comment":"","action":"DROP","params":[{"is_inverted":false,"name":"--protocol","value":"tcp"},{"is_inverted":false,"name":"--match","value":"tcp"},{"is_inverted":false,"name":"--tcp-flags","value":"SYN,RST SYN,RST"}]},{"is_disabled":false,"comment":"","action":"DROP","params":[{"is_inverted":false,"name":"--source","value":"::1\/128"},{"is_inverted":true,"name":"--in-interface","value":"lo"}]}]},"Friend":{"name":"Friend","comment":"","rules":[{"is_disabled":false,"comment":"","action":"RETURN","params":[]}]},"fail2ban":{"name":"fail2ban","comment":"","rules":[]}}' WHERE `ip_version` = 'ipv6' AND `type` = 'current'
