Meine älteren Scripte die nicht PHP 7 unterstützen funktionieren damit wunderbar. Falls ich jemanden damit helfen konnte .. gerne
Die Datei hier mal als mysql_wrapper.php bezeichnet die bspw in die config Datei included werden sollte.
<?php
* mysql_wrapper.php
if(!function_exists("mysql_connect"))
if(!extension_loaded("mysqli"))
trigger_error("MySQLi extension must be loaded.", E_USER_ERROR);
define("MYSQL_NUM", MYSQLI_NUM);
define("MYSQL_ASSOC", MYSQLI_ASSOC);
define("MYSQL_BOTH", MYSQLI_BOTH);
define("MYSQL_CLIENT_COMPRESS", NULL);
define("MYSQL_CLIENT_IGNORE_SPACE", NULL);
define("MYSQL_CLIENT_INTERACTIVE", NULL);
$__mysql = NULL;
* Start connections and functions
function mysql_not_implemented($function)
trigger_error("The $function function is not available for this Script. Complete function on mysql_wrapper.php to use it!", E_USER_WARNING);
return false;
function mysql_resolve_link($link)
global $__mysql;
if($link == NULL)
if(!is_object($__mysql))
trigger_error("invalid link handle, connect to database", E_USER_ERROR);
else
return $__mysql;
return $link;
function mysql_connect($host = NULL, $user = NULL, $pass = NULL, $new = false, $flags = 0)
global $__mysql;
$extra_info = substr(strstr($host, ":"), 1);
if(!empty($extra_info))
if(is_numeric($extra_info))
$port = $extra_info;
else
$socket = $extra_info;
$host = substr($host, 0, strlen($host)-(strlen($extra_info)+1));
if(empty($socket))
if(empty($port))
$__mysql = mysqli_connect($host, $user, $pass);
else
$__mysql = mysqli_connect($host, $user, $pass, NULL, $port);
else
$__mysql = mysqli_connect($host, $user, $pass, NULL, NULL, $socket);
return $__mysql;
function mysql_select_db($dbname, $link = NULL)
$link = mysql_resolve_link($link);
return mysqli_select_db($link, $dbname);
function mysql_query($query, $link = NULL)
return mysqli_query($link, $query);
function mysql_fetch_assoc($result)
return mysqli_fetch_assoc($result);
function mysql_fetch_array($result, $type = NULL)
return mysqli_fetch_array($result, $type);
function mysql_fetch_field($result, $offset = NULL)
if($offset != NULL)
for($i = 0; ($i < $offset) || !($retval = mysqli_fetch_field($result)); $i++)
/* not ready yet... */
else
return mysqli_fetch_field($result);
return ($retval) ? $retval : false;
function mysql_close($link = NULL)
return mysqli_close($link);
function mysql_affected_rows($link = NULL)
return mysqli_affected_rows($link);
function mysql_change_user($user, $passwd, $database = NULL, $link = NULL)
return mysqli_change_user($link, $user, $passwd, $database);
function mysql_client_encoding($link = NULL)
return mysqli_character_set_name($link);
function mysql_create_db($database, $link = NULL)
$query = "CREATE DATABASE $database";
$result = msyqli_query($link, $query);
return (!$result) ? false : true;
function mysql_data_seek($result, $row)
return mysqli_data_seek($result, $row);
function mysql_db_name($result, $row, $field = NULL)
return mysql_not_implemented("mysql_db_name()");
function mysql_db_query($database, $query, $link = NULL)
mysqli_select_db($link, $database);
function mysql_drop_db($database, $link = NULL)
$query = "DROP DATABASE $database";
$result = mysqli_query($link, $query);
function mysql_error($link = NULL)
return mysqli_error($link);
function mysql_errno($link = NULL)
return mysqli_errno($link);
function mysql_escape_string($string)
$link = mysql_resolve_link(NULL);
return mysqli_real_escape_string($link, $string);
function mysql_fetch_lengths($result)
return mysqli_fetch_lengths($result);
function mysql_fetch_object($result)
return mysqli_fetch_object($result);
function mysql_fetch_row($result)
return mysqli_fetch_row($result);
function mysql_field_flags($result, $offset)
return mysql_not_implemented("mysql_field_flags()");
function mysql_field_len($result, $offset)
return mysql_not_implemented("mysql_field_len()");
function mysql_field_name($result, $offset)
$finfo = mysqli_fetch_field_direct($result, $offset);
return $finfo->name;
function mysql_field_seek($result, $offset)
return mysqli_field_seek($resutl, $offset);
function mysql_field_table($result, $offset)
return mysql_not_implemented("mysql_field_table()");
function mysql_field_type($result, $offset)
return mysql_not_implemented("mysql_field_type()");
function mysql_free_result($result)
return mysqli_free_result($result);
function mysql_get_client_info()
return mysqli_get_client_info();
function mysql_get_host_info($link = NULL)
return mysqli_get_client_info($link);
function mysql_get_proto_info($link = NULL)
return mysqli_get_proto_info($link);
function mysql_get_server_info($link = NULL)
return mysqli_get_server_info($link);
function mysql_info($link = NULL)
return mysqli_info($link);
function mysql_insert_id($link = NULL)
return mysqli_insert_id($link);
function mysql_list_dbs($link = NULL)
$query = "SHOW DATABASES";
function mysql_list_fields($database, $table, $link = NULL)
return mysql_not_implemented("mysql_list_fields()");
function mysql_list_processes($link = NULL)
return mysql_not_implemented("mysql_list_processes()");
function mysql_list_tables($database, $link = NULL)
return mysql_not_implemented("mysql_list_tables()");
function mysql_num_fields($result)
return mysqli_num_fields($result);
function mysql_num_rows($result)
return mysqli_num_rows($result);
function mysql_pconnect($host = NULL, $user = NULL, $passwd = NULL, $flags = NULL)
return mysql_connect($host, $user, $passwd, false, $flags);
function mysql_ping($link = NULL)
return mysqli_ping($link);
function mysql_real_escape_string($string, $link = NULL)
function mysql_result($result, $row, $field = NULL)
if($result->num_rows==0) return 'unknown';
$result->data_seek($row);
$ceva=$result->fetch_assoc();
return (isset($ceva[$field])?$ceva[$field]
:(strpos($field,'.')?$ceva[substr($field,strrpos($field,'.')+1)]:''));
function mysql_stat($link = NULL)
return mysqli_stat($link);
function mysql_tablename($result, $offset)
return mysql_not_implemented("mysql_tablename()");
function mysql_thread_id($link = NULL)
return mysqli_thread_id($link);
function mysql_unbuffered_query($query, $link = NULL, $result_mode = NULL)
return mysql_not_implemented("mysql_unbuffered_query()");
function mysql_set_charset($link, $charakter)
return mysql_set_charset($charakter,$link);
