PHP version upgrade
info@eurhosting.net
PHP version upgrade
Post by info@eurhosting.net »
Hello
I'm pretty sure that a script to upgrade php version on keyhelp has been done but I can't it anywhere.
At the moment my server is running php 5.5.9 on Ubuntu 14.04 (64-Bit) and latest version of KeyHelp.
Trying to install Siberian CMS but require at least php 5.6
Any help is appreciated
Stop stop stop
If hosting is not your main focus, I can be of help to mantain your servers
Re: PHP version upgrade
As far as i know it is not possible to upgrade PHP with Ubuntu 14.
You could change to Debian 8. This supports PHP 5.6.
Ubuntu 16 has already PHP 7.
PHP version switcher is on the todo list of keyhelp.
Hopefully different PHP versions on different domains will be possible in the future.
If you upgrade PHP somehow, be aware that your pre PHP 5.6 scripts might not be compatible with PHP > 5.6.
script and instructions for upgrading from Ubuntu 14.04 to 16.04 can be found here:
https://www.keyhelp.de/en/news/upgrade- ... 16-04-lts/
Reseller4711
Post by Reseller4711 »
This would be great. Still waiting :D
info@eurhosting.net
Thank you Martin
Exactly the one I was talking about :)
Stop stop stop
