Let's Encrypt does not start
- dataproject
I've 2 domain on keyweb.de, to one of them I have activate SSL Certificate Let's Encrypt but it does not operate from 2 hour about activation.
Browser calling https://www.mydomain.ext tell
www.domain.ext uses an invalid security certificate.
The certificate is only valid for kmXXXXX.keymachine.de
Error code: SSL_ERROR_BAD_CERT_DOMAIN
Perhaps should I install certbot-auto client ?
Any other suggestions?
Thank you
Re: Let's Encrypt does not start
It looks like your domain is using the wrong certificate.
Did your domain work correctly without any certificate?
I mean HTTP only?
Maybe the routing of the domain is wrong.
Check the server path where your domain points to.
- dataproject
domain work correctly on http.
There is also a old "default" certificate on SSL Certificate page, used only for administration and that I cannot delete or set to new "Let's Crypt".
Thank u
Then you probably need a second certificate for your TLD.
I think you must add this certificate under SSL Certificates, then press the blue button "Add SSL certificate".
You can get a free certificte here: https://www.startssl.com/Validate
Just upload the provided files in keyhelp.
If you are unsure abaout that, then you could try this step first with a self-signed certificate.
Hope this helps and works
- info@eurhosting.net
- KeyHelp Translator
I have the same issue on domain running under cloudflar and using CDN, still trying to solve that
If hosting is not your main focus, I can be of help to mantain your servers
- dataproject
I did't show the subdomains
Clicking the button "Show Subdomain" i could activate Let's Crypt for subdomains like www !!!!
But now another problem
The link System Logs & Status / Server Messages say
a lets encrypt error occurred for domain "subdomain.mydomain.ext"
but there's no any detail log.
DNS is correctly like other subdomain that function correclty.
I've thought it was number limit of subdomain for Let's Encrypt, but disabling other that function correctly, those don't start anyway !
Some suggestions ???
Thank you.
But I get this ssl-error, if the subdomain show / linking to a empty directory (without index.htm).
Nikko
That's correct.nikko wrote:Maybe there is a limit for request of subdomains.
Here are some additional infos about the limits.
You can find more details in one of the two logs.The link System Logs & Status / Server Messages say
Go to "Panel Taks Logs". Here you have the
"update.log")
- If you enable Let's Encrypt for a domain, it will write the log into this file.
- It will contain all manually started Let's Encrypt changes
and the "letsencrypt.log")
- Here you will find all automatically performed updates to Let's Encrypt. The corresponding cronjob, which checks if Let's Encrypt certs are still valid (and refresh them, if needed) will write its log here.
- dataproject
Do you know if should I revoke someone certificate's subdomain less important instead of other ?
Thank you
this is only a temporary limit. You can add 20 certificates for any domain per week. Just wait a week and you can add another.
If a certificate is issued, renew will work without problem (as there is no rate limit for this).
- dataproject
