Installation on Ubuntu 14.04
valdeg
Post by valdeg »
Hello, I got a problem installing keyhelp on Ubuntu 14.04. Every time I try to start installation script I'm getting a message that my account dont have enough priviligies even when I'm using sudo.
Am I getting it right, that the only way to install keyhelp is enabling root (that worked for me.)
Re: Installation on Ubuntu 14.04
this is correct, KeyHelp must be installed as User "root", because it needs to install the nessesary services (Apache, PHP, etc).
If you don't want to set a root password in Ubuntu, you can switch to root using the following command:
sudo su -
rocky700
Post by rocky700 »
I am also getting problem while installing the key help as the system screen is getting blue and I am not being able to see anything. There must be a bug that is creating the problem while installation and I think it has to be fixed as soon as possible.
ERROR CODE 0XC0000428
Can you post a screenshot, of whats happening on your system?
