Installation geht durch aber mit QOUTA FEHLER  [GELÖST]
umutkuepeli
Post by umutkuepeli »
Die installation geht durch aber mit einem Quote fehler konnte leider im Forum keine Lösung finden füge mal paar logs etc hinzu
/var/log/keyhelp/install.log :
 [Quota]
  exec | apt-get install -y quota quotatool
    Reading package lists...
    Building dependency tree...
    Reading state information...
    quota is already the newest version.
    The following NEW packages will be installed:
      quotatool
    0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
    Need to get 17.8 kB of archives.
    After this operation, 70.7 kB of additional disk space will be used.
    Get:1 http://ftp.debian.org/debian/ jessie/main quotatool amd64 1:1.4.12-2 [17.8 kB]
    perl: warning: Setting locale failed.
    perl: warning: Please check that your locale settings:
        LANGUAGE = (unset),
        LC_ALL = (unset),
        LANG = "de_DE.UTF-8"
        are supported and installed on your system.
    perl: warning: Falling back to the standard locale ("C").
    locale: Cannot set LC_CTYPE to default locale: No such file or directory
    locale: Cannot set LC_MESSAGES to default locale: No such file or directory
    locale: Cannot set LC_ALL to default locale: No such file or directory
    Fetched 17.8 kB in 0s (279 kB/s)
    Selecting previously unselected package quotatool.
    (Reading database ... ^M(Reading database ... 5%^M(Reading database ... 10%^M(Reading database ... 15%^M(Reading database ... 20%^M(Reading database ... 25%^M(Reading database ... 30%^M(Reading database ... 35%^M(Reading database ... 40%^M(Reading database ... 45%^$
    Preparing to unpack .../quotatool_1%3a1.4.12-2_amd64.deb ...
    Unpacking quotatool (1:1.4.12-2) ...
    Processing triggers for man-db (2.7.0.2-5) ...
    Setting up quotatool (1:1.4.12-2) ...
  exec | service quota stop
  exec | cp /etc/fstab /etc/fstab-backup
  exec | echo "/dev/simfs     /     simfs     rw,relatime,usrquota,grpquota     0     1
proc  /proc       proc    defaults    0    0
none  /dev/pts    devpts  rw,gid=5,mode=620    0    0
none  /run/shm    tmpfs   defaults    0    0" > "/etc/fstab"
  exec | mount -o remount /
    mount: permission denied
    !!! ERROR DETECTED !!!
  [SKIPPED DUE PREVIOUS ERRORS] exec | quotacheck -avmug
  [SKIPPED DUE PREVIOUS ERRORS] exec | service quota start
Re: Installation geht durch aber mit QOUTA FEHLER  [GELÖST]
sofern es sich um ein OpenVZ System handelt, so wäre diese spezifische Fehler normal. Durch den Neustart des Systems nach der Installation hat dies für die Funktionsfähigkeit keine Auswirkungen. (lediglich der Remount während der Installation schlägt fehl)
umutkuepeli
Also ist dies Normal und hat keine Auswirkung ?
saugjunkie
Post by saugjunkie »
Auswirkungen hat es schon du kannst quota nicht benutzen was wenn du nicht vor hast irgendwelche Leute webhosting anzubieten nicht weiter stört. Da wir ja nun davon ausgehen das du einen openvz Server hast.
Hier noch eine kurze Erläuterung wieso du da Probleme mit quota hast. Kurz um dein openvz Server beansprucht das schon und regelt darüber deinen verfügbaren Speicherplatz auf dem node.
MFG
Saugjunkie
@saugjunkie: Generell richtig, aber wie aus seinem speziellen Fehler zu entnehmen ist hat er den Quotamountpoint korrekt angelegt. Lediglich der Remount schlägt fehl.
Dieser spezifische Fehler hat für den generellen Betrieb wie geschrieben keinerlei Auswirkungen. (es handelt sich hier NICHT um den "missing quota mountpoint Fehler)
saugjunkie
Setzten 6 :lol:
@Martin vielen dank für die Aufklärung hab nur openvz und quota gelesen und mir gar nicht die genaue Fehlermeldung.
MFG
Saugjunkie
meistermitte
Post by meistermitte »
Moin ihr lieben wollte mal nach langen wieder das system testen nur habe ich auch den Fehler ,und weiss nicht was ich da genau eintragen soll in der Fstab ich habe proxmox drauf Virtuell mit debian 8 ,
Vielen Dank
mount
/var/lib/vz/images/100/vm-100-disk-1.raw on / type ext4 (rw,relatime,data=ordere d)
none on /dev type tmpfs (rw,relatime,size=492k,mode=755)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
proc on /proc/sys/net type proc (rw,nosuid,nodev,noexec,relatime)
proc on /proc/sys type proc (ro,nosuid,nodev,noexec,relatime)
proc on /proc/sysrq-trigger type proc (ro,nosuid,nodev,noexec,relatime)
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
sysfs on /sys type sysfs (ro,nosuid,nodev,noexec,relatime)
sysfs on /sys/devices/virtual/net type sysfs (rw,relatime)
sysfs on /sys/devices/virtual/net type sysfs (rw,nosuid,nodev,noexec,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
lxcfs on /proc/cpuinfo type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group _id=0,allow_other)
lxcfs on /proc/diskstats type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,gro up_id=0,allow_other)
lxcfs on /proc/meminfo type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group _id=0,allow_other)
lxcfs on /proc/stat type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id =0,allow_other)
lxcfs on /proc/swaps type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_i d=0,allow_other)
lxcfs on /proc/uptime type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_ id=0,allow_other)
devpts on /dev/console type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptm xmode=000)
devpts on /dev/pts type devpts (rw,relatime,gid=5,mode=620,ptmxmode=666)
devpts on /dev/tty1 type devpts (rw,relatime,gid=5,mode=620,ptmxmode=666)
devpts on /dev/tty2 type devpts (rw,relatime,gid=5,mode=620,ptmxmode=666)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xa ttr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpu set)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatim e,cpu,cpuacct)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blki o)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,mem ory)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,de vices)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,fr eezer)
cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,re latime,net_cls,net_prio)
cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime ,perf_event)
cgroup on /sys/fs/cgroup/hugetlb type cgroup (rw,nosuid,nodev,noexec,relatime,hu getlb)
cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
mqueue on /dev/mqueue type mqueue (rw,relatime)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime)
tmpfs on /tmp type tmpfs (rw)
none on /run/shm type tmpfs (rw,relatime)
Fstab
bei dem Fehler handelt es sich um den "klassischen" Quota-Fehler (fehlender fstab Eintrag). Hierzu gibt es den Lösungsansatz in einigen weiteren Threads.
Der in diesem Thema behandelte Fehler ist hiervon unabhängig.
