Connection Error: 1045 (Access denied for user 'root'@'localhost' (using password: NO))  [SOLVED]
silenzium
Post by silenzium »
first of all thanks for the free admin panel.
I just wanted to install it to try it out but got errors during installation. I try to install on a fresh setup Debian 9 LAMP Stack from Hetzner.
When I first started the installation with the
installkeyhelp.sh
I got an error "Access denied for user 'root'@'localhost' (using password: NO)", so I opened mariadb and reset root passwort with
SET PASSWORD FOR root@localhost=PASSWORD('');
and rerun the
installkeyhelp.sh
Then it went through untill the configuration step where I can change admin user name and password etc.
Then I hit "S" for "Start install" and the following happened:
Installation is running:
Update sources list ...                     [OKAY]
Installation requirements ...               [OKAY]
Sudo ...                                    [OKAY]
Bind9 ...                                   [OKAY]
SSL ...                                     [OKAY]
PHP ...                                     [OKAY]
Apache ...                                  [OKAY]
PHP-FPM ...                                 [OKAY]
MariaDB ...
Warning: MySQL - Connection Error: 1045 (Access denied for user 'root'@'localhost' (using password: NO)) in /home/keyhelp/www/keyhelp/core/pending/DBConnection.php on line                                    170
Warning: mysqli::query(): Couldn't fetch mysqli in /home/keyhelp/www/keyhelp/core/pending/DBConnection.php on line 49
Warning: mysqli::query(): Couldn't fetch mysqli in /home/keyhelp/www/keyhelp/core/pending/DBConnection.php on line 50
Warning: mysqli::query(): Couldn't fetch mysqli in /home/keyhelp/www/keyhelp/core/pending/DBConnection.php on line 69
Warning: DBConnection::query(): Couldn't fetch mysqli in /home/keyhelp/www/keyhelp/core/pending/DBConnection.php on line 70
Warning: MySQL - Query Error:  () in /home/keyhelp/www/keyhelp/core/pending/DBConnection.php on line 170
[ERROR]
KeyHelp ...
[ERROR]
Firewall (iptables) ...
[ERROR]
SSH ...                                     [OKAY]
ProFTPD ...                                 [OKAY]
Postfix ...                                 [OKAY]
Dovecot ...                                 [OKAY]
Email protection
    Postgrey, Amavis, ClamAV,
    SpamAssassin, Pyzor, Razor ...          [ERROR]
AWStats ...                                 [ERROR]
Fail2ban ...                                [ERROR]
Logrotate ...                               [ERROR]
PhpMyAdmin 4.7.5 Multilanguage ...
[ERROR]
Roundcube 1.3.3 Multilanguage ...
[ERROR]
Rainloop 1.11.0.203 (Community Edition) ...
[ERROR]
Quota ...                                   [ERROR]
Apparmor ...                                [ERROR]
7-Zip ...                                   [ERROR]
Nano ...                                    [ERROR]
NTP ...                                     [ERROR]
Cron-Daemon ...                             [ERROR]
Warning: MySQL - Connection Error: 1045 (Access denied for user 'keyhelp'@'localhost' (using password: YES)) in /home/keyhelp/www/keyhelp/core/pending/DBConnection.php on line 170
Fatal error: Uncaught Error: Call to a member function fetch_assoc() on null in /home/keyhelp/www/keyhelp/core/Settings/Settings.php:240
Stack trace:
#0 /home/keyhelp/www/keyhelp/core/Settings/Settings.php(51): Settings->loadSettings()
#1 /home/keyhelp/www/keyhelp/install/install.php(829): Settings->__construct(Object(DBConnection))
#2 {main}
  thrown in /home/keyhelp/www/keyhelp/core/Settings/Settings.php on line 240
And now I can not access
mysql -u root
anymore. Does the installer change the mysql root password during the installation and what can I do to successfully install KeyHelp?
Thanks in advance!
Re: Connection Error: 1045 (Access denied for user 'root'@'localhost' (using password: NO))
Hello silenzium,
KeyHelp requires a clean (minimal) operating system set up on the server. The components included in a LAMP image all get installed and configured by KeyHelp during its installation process, so it is not advisable to install them in advance.
The reason why KeyHelp fails in particular in your situation is, that there is already a MySQL/MariaDB installation on your system due to the LAMP image. KeyHelp needs the root access to the database to fullfill various tasks and is unable to receive the login credentials for this database.
Solution: Reset your server and choose the Hetzner minimal image of your desired operating system - then start the KeyHelp installation again.
silenzium
Re: Connection Error: 1045 (Access denied for user 'root'@'localhost' (using password: NO))  [SOLVED]
Post by silenzium »
I just retried with a fresh Debian 9 minimal setup (no LAMP) and it worked!
Thanks!
Best, Lorenz
