The language selection is missing (New Design)  [SOLVED]
majorboobage
Post by majorboobage »
https://demo.keyhelp.de/
Login page in English. The panel itself is in German.
Re: The language selection is missing (New Design)
Click on the user icon after login.
You can change the language settings there.
If it was your own user account, you could save the settings permanently.
I think i missunderstood your question.
If you change the settings in the backend the login remains in German anyway?
And the language selector is gone...
Normally the language selection on the login page is not used and in 99% of cases not needed. Every user who wants to log in has his own account where he can change to the desired language.
But I forgot about the demo.keyhelp.de server. In this special case the language selection makes much more sense.
I think we better install a new demo server for our English users (I'll keep you updated).
Thank you for pointing that out.
majorboobage
English demo, that would be great!
Thanks!
Re: The language selection is missing (New Design)  [SOLVED]
Greetings,
here it is:
https://demo.keyhelp.eu
(DNS just updated some hours ago, if you have problems reaching it, try https://62.141.57.171 - tomorrow it should be fine)
