Ubuntu Upgrade läuft nicht  [GELÖST]
ECHTkochen
Post by ECHTkochen »
Hallo,ich wollte gerne dank des tollen Scripts das Ubuntu Upgrade machen aber wenn ich die php datei starten will kommt nur folgende meldung:
   _  __          _   _     _    (R)
  | |/ /___ _   _| |_| |___| |___
  | | /  -_) |_/ |  _  | -_) | _ \
  |_|\_\___|\__, |_| |_|___|_|  _/ Your Administration-Panel
=========== |___/ ========== |_| =========================================
This script performs an operating system upgrade on your server.
- Instructions -----------------------------------------------------------
Step 1)
This script performs necessary tasks in preparation for the upgrade.
Step 2)
The program flow is handed over to the ubuntu application
"do-release-upgrade". Please follow the instructions of this program.
The system is then rebooted.
Note: On questions about "Should system config files be overwritten"
please answer with "Keep the local version currently installed".
Step 3)
Please run the command "phpenmod ioncube". Then start this script again
with "php keyhelp_ubuntu_upgrade_16_to_18.php"
Step 4)
Updates configuration files, then reboots the system. Your server is now
ready for use.
Note: Once you begin the upgrade, you should go through it completely.
If you cancel the upgrade during execution, any changes must be manually
undone. It is highly recommended to make a backup in advance!
> Pre-checking system...
Error: The following files need to be updated and are not readable or
writable. Please set correct file permissions.
/etc/update-manager/release-upgrades
Hoffe ihr könnt mir helfen.
Besucht mich! :
Homepage | Facebook | Twitter
Re: Ubuntu Upgrade läuft nicht
Was sagt denn ein:
ls -al /etc/update-manager/release-upgrades
ECHTkochen
Das sagt folgendes:
total 8
drwxr-xr-x 2 root root 4096 Feb 27 09:31 .
drwxr-xr-x 3 root root 4096 Feb 27 09:31 ..
Besucht mich! :
Hast du das Script als root ausgeführt?
ECHTkochen
ja ich habe es als Root ausgeführt.
Besucht mich! :
die Datei release-upgrades scheint hier zu fehlen. Ist "update-manager-core" korrekt installiert?
ECHTkochen
war nicht installiert habe es jetzt aber nachträglich mit
apt install update-manager-core
installiert aber das Problem ist immer noch da.
Besucht mich! :
ECHTkochen
Ich glaube ich mache es einfach manuell....
Backup machen von Datenbank, FTP und eine neuinstallation geht glaube ich schneller und ist auch cleaner :D
Besucht mich! :
ECHTkochen
Re: Ubuntu Upgrade läuft nicht  [GELÖST]
So hat sich erledigt neuer Server mit 16GB Ram und 400GB RAM konnte meinen Tarif umtauschen bzw. Upgraden und somit habe ich auch gleich das OS gewechselt.
Also nutze ich nun Keyhelp mit Debian 9
Besucht mich! :
