Disable some services..
kaz050457
Post by kaz050457 »
Tried to disable some mail services like clamav..But it coming back...How to permanent disable?
kaz050457
Re: Disable some services..
Post by kaz050457 »
Fixed its coming back because still up on server maintenance..
'clamav-daemon' is restarted only the first 60 minutes after reboot. After that time, it can then be deactivated without being "awakened" via the KeyHelp maintenance run.
v3ng
Post by v3ng »
@Alexander it would be awesome if services like the mail filtering would be optional. So the user would have the option in the installer, if he wants to use the resource intensive filtering.
