fehler installation ubuntu 16.04
nexusfxp
Post by nexusfxp »
Hallo
Schön langsam bin ich am verzweifeln
nach mehrmaligen versuch es zu installieren mit verschiedenen Distro,und den verschiedenen beiträgen von hier
iist das mein letzter versuch
Server: vserver ubuntu-16.04-x86_64 &Openvz
kann keine minimal installation machen
update auf ubuntu 18 mit dem Script von hier funkioniert auch nicht
_ __ _ _ _ (R)
| |/ /___ _ _| |_| |___| |___
| | / -_) |_/ | _ | -_) | _ \
|_|\_\___|\__, |_| |_|___|_| _/ Ihr Administrations-Panel
=========== |___/ ========== |_| =========================================
Installation wird durchgeführt:
Update sources list ... [OKAY]
Installation requirements ... [OKAY]
Sudo ... [OKAY]
Bind9 ... [OKAY]
SSL/TLS ... [OKAY]
PHP ... [OKAY]
Apache ... [OKAY]
PHP-FPM ... [OKAY]
MariaDB ... [ERROR]
KeyHelp ...
Warning: MySQL - Connection Error: 2002 (No such file or directory) in /home/keyhelp/www/k eyhelp/core/pending/DBConnection.php on line 229
Warning: mysqli::query(): Couldn't fetch mysqli in /home/keyhelp/www/keyhelp/core/pending/ DBConnection.php on line 53
Warning: mysqli::query(): Couldn't fetch mysqli in /home/keyhelp/www/keyhelp/core/pending/ DBConnection.php on line 54
Warning: mysqli::query(): Couldn't fetch mysqli in /home/keyhelp/www/keyhelp/core/pending/ DBConnection.php on line 77
Warning: DBConnection::query(): Couldn't fetch mysqli in /home/keyhelp/www/keyhelp/core/pe nding/DBConnection.php on line 78
[ERROR]
Firewall (iptables) ...
[ERROR]
SSH ... [OKAY]
ProFTPD ... [ERROR]
Postfix ... [ERROR]
Dovecot ... [ERROR]
OpenDKIM ... [OKAY]
Email protection
Postgrey, Amavis, ClamAV,
SpamAssassin, Pyzor, Razor ... [ERROR]
AWStats ... [OKAY]
Fail2ban ... [OKAY]
Logrotate ... [OKAY]
PhpMyAdmin 4.8.5 Multilanguage ...
Warning: MySQL - Connection Error: 2002 (No such file or directory) in /home/keyhelp/www/keyhelp/core/p ending/DBConnection.php on line 229
Warning: mysqli::query(): Couldn't fetch mysqli in /home/keyhelp/www/keyhelp/core/pending/DBConnection. php on line 53
Warning: mysqli::query(): Couldn't fetch mysqli in /home/keyhelp/www/keyhelp/core/pending/DBConnection. php on line 54
Warning: mysqli::query(): Couldn't fetch mysqli in /home/keyhelp/www/keyhelp/core/pending/DBConnection. php on line 77
Warning: DBConnection::query(): Couldn't fetch mysqli in /home/keyhelp/www/keyhelp/core/pending/DBConne ction.php on line 78
[ERROR]
Roundcube 1.3.8 Multilanguage ...
[ERROR]
Rainloop 1.12.1 (Community Edition) ...
[ERROR]
Quota ... [ERROR]
Apparmor ... [OKAY]
7-Zip ... [OKAY]
Update MotD ... [OKAY]
Nano ... [OKAY]
NTP ... [ERROR]
Cron-Daemon ... [OKAY]
Fatal error: Uncaught Error: Call to a member function fetch_assoc() on null in /home/keyhelp/www/keyhe lp/core/Settings/Settings.php:242
Stack trace:
#0 /home/keyhelp/www/keyhelp/core/Settings/Settings.php(51): Settings->loadSettings()
#1 /home/keyhelp/www/keyhelp/install/install.php(871): Settings->__construct(Object(DBConnection))
#2 {main}
thrown in /home/keyhelp/www/keyhelp/core/Settings/Settings.php on line 242
root@shop-htdv:~#
hoffe es kann mir jemand weiterhelfen
oder es findet sich jemand der es mir installiert
anbei hab ich den install-log angehängt
mfg
nexusfxp
install.log
(306.07 KiB) Downloaded 387 times
MLan
Re: fehler installation ubuntu 16.04
Post by MLan »
    WARNING: The following packages cannot be authenticated!
      mysql-common mariadb-common libmysqlclient18 libmariadbclient18
      mariadb-client-core-10.0 mariadb-client-10.0 mariadb-server-core-10.0
      mariadb-server-10.0 mariadb-server
    E: There were unauthenticated packages and -y was used without --allow-unauthenticated
Gruß Mlan
    W: GPG error: http://mirror2.hs-esslingen.de/mariadb/repo/10.0/ubuntu trusty InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY CBCB082A1BB943DB
    W: The repository 'http://mirror2.hs-esslingen.de/mariadb/repo/10.0/ubuntu trusty InRelease' is not signed.
Aus welchen Gründen auch immer, der GPG-Key von MariaDB kann nicht geladen werden.
Aufgrund dessen kann der DB-Server nicht installiert werden, alle anderen Fehler sind Folgefehler aufgrund des fehlenden DB-Servers.
nexusfxp wrote: Fri 22. Mar 2019, 16:18 kann keine minimal installation machen
Was genau willst du damit sagen?
Hast du versucht, Keyhelp auf einem bereits mit Software bestücktem Server zu installieren?
nexusfxp wrote: Fri 22. Mar 2019, 16:18 update auf ubuntu 18 mit dem Script von hier funkioniert auch nicht
Kann auch nicht funktionieren, wenn schon die Installation unter Ubuntu 16 massenweise Fehler wirft...
BTW (@Dev's):
Ist MariaDB bei Ubuntu nicht in den Standardrepos drin?
Zumindest bei Debian seit Version 8 ist es mit drin, so daß man keine expliziten Sourcen dafür angeben und entsprechende GPG-Keys ziehen muß.
nexusfxp
Post by nexusfxp »
habe jedesmal den Server neu aufgesetzt,nach fehlermeldung bei keyhelp installaton
könnte noch versuchen die mariaDB vorher zu installieren
hatte bei Debin 9 auch jede menge fehler
ich versuch es mal mit der mariaDB zuerst installiern
Da du im Startpost erwähntest, daß es sich um eine OpenVZ-Kiste handelt, noch 2 zusätzliche Fragen:
Welche Ressourcen (speziell wieviel RAM) stehen dir auf deinem vServer zur Verfügung?
Was sagt ein:
cat /proc/user_beancounters
nexusfxp
Post by nexusfxp »
laut ihnen 3GB
user_beancounters.txt
(3.11 KiB) Downloaded 400 times
nexusfxp wrote: Fri 22. Mar 2019, 18:46 laut ihnen 3GB
RAM sollte auf jeden Fall ausreichend sein, die beancounters sehen soweit auch okay aus.
Edit:
Probier mal, den aktuellen GPG-Key selber abzuholen, bevor du den Keyhelp-Installer startest:
sudo apt-key adv --recv-keys --keyserver hkp://keyserver.ubuntu.com:80 0xcbcb082a1bb943db
Quelle: https://mariadb.com/kb/en/library/insta ... public-key
Ungetestet, da ich weder eine OpenVZ-Kiste zum Testen greifbar habe und auch sonst eigentlich nur Debian einsetze.
nexusfxp
Post by nexusfxp »
leider hing sich die installation ,in der nacht auf,
werde es heute nachmittag nochmal probieren
@Jolinar
Danke für die Tips
nexusfxp
Post by nexusfxp »
leider bekomme ich es nicht gebacken :evil:
bleibt immer wieder hängen,(ohne error)
schade hat mir von der Demo gut gefallen
@all ein schöne WE
mfg
nexusfxp
P.S: sollte sich jemand finden,der es versuchen will,einfach eine PN
nikko
Post by nikko »
Doch, mariaDB sollte in den Repos drin sein.
Das sieht mir verdammt nach einer schlecht konfigurierten OpenVZ Virtualiserung aus. Vielleicht hat er Sorgen beim Allozieren des Speichers oder irgendwelche shmpages - Werte sind schon am Limit... es weiß ja keiner, welche Begrenzungen wo gesetzt worden sind - außer die SU.
@nexusfxp - Wenn die Möglichkeit besteht, sieh dich nach einem anderen V-Server um.
