ProFTPd zerstört  [GELÖST]
Justin1804
ProFTPd zerstört
Post by Justin1804 »
ich habe irgendwie den ProFTPd zerstört so das er keine User mehr anlegt über KeyHelp.
Was könnte ich da machen?
Als System läuft Debian 9
die Config sieht wie folgt aus:
# /etc/proftpd/proftpd.conf -- This is a basic ProFTPD configuration file.
# To really apply changes, reload proftpd after modifications, if
# it runs in daemon mode. It is not required in inetd/xinetd mode.
# Includes DSO modules
Include /etc/proftpd/modules.conf
# Set off to disable IPv6 support which is annoying on IPv4 only boxes.
UseIPv6                     on
# If set on you can experience a longer connection delay in many cases.
ServerName                  "moepmoep FTP over SSL Server"
ServerType                  standalone
DeferWelcome                off
MultilineRFC2228            on
DefaultServer               on
ShowSymlinks                on
TimeoutNoTransfer           600
TimeoutStalled              600
TimeoutIdle                 1200
DisplayLogin                welcome.msg
DisplayChdir                .message true
ListOptions                 "-l"
DenyFilter                  \*.*/
# Use this to jail all users in their homes
# Users require a valid shell listed in /etc/shells to login.
# Use this directive to release that constrain.
# RequireValidShell         off
# Port 21 is the standard FTP port.
Port                        21
# In some cases you have to specify passive ports range to by-pass
# firewall limitations. Ephemeral ports can be used for that, but
# feel free to use a more narrow range.
PassivePorts                30000 30500
# If your host was NATted, this option is useful in order to
# allow passive tranfers to work. You have to use your public
# address and opening the passive ports used on your firewall as well.
# MasqueradeAddress         1.2.3.4
# This is useful for masquerading address with dynamic IPs:
# refresh any configured MasqueradeAddress directives every 8 hours
<IfModule mod_dynmasq.c>
# DynMasqRefresh 28800
</IfModule>
# To prevent DoS attacks, set the maximum number of child processes
# to 30.  If you need to allow more than 30 concurrent connections
# at once, simply increase this value.  Note that this ONLY works
# in standalone mode, in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd)
MaxInstances                30
# Set the user and group that the server normally runs at.
User                        proftpd
Group                       nogroup
# Umask 022 is a good standard umask to prevent new files and dirs
# (second parm) from being group and world writable.
Umask                   022  022
# Normally, we want files to be overwriteable.
AllowRetrieveRestart        on
AllowStoreRestart           on
# Uncomment this if you are using NIS or LDAP via NSS to retrieve passwords:
# PersistentPasswd          off
# This is required to use both PAM-based authentication and local passwords
# AuthOrder                 mod_auth_pam.c* mod_auth_unix.c
# Be warned: use of this directive impacts CPU average load!
# Uncomment this if you like to see progress and transfer rate with ftpwho
# in downloads. That is not needed for uploads rates.
# UseSendFile               off
TransferLog /var/log/proftpd/xferlog
SystemLog   /var/log/proftpd/proftpd.log
# Logging onto /var/log/lastlog is enabled but set to off by default
#UseLastlog on
# In order to keep log file dates consistent after chroot, use timezone info
# from /etc/localtime.  If this is not set, and proftpd is configured to
# chroot (e.g. DefaultRoot or <Anonymous>), it will use the non-daylight
# savings timezone regardless of whether DST is in effect.
#SetEnv TZ :/etc/localtime
<IfModule mod_quotatab.c>
QuotaEngine off
</IfModule>
<IfModule mod_ratio.c>
Ratios off
</IfModule>
# Delay engine reduces impact of the so-called Timing Attack described in
# http://www.securityfocus.com/bid/11430/discuss
# It is on by default.
<IfModule mod_delay.c>
DelayEngine on
</IfModule>
<IfModule mod_ctrls.c>
ControlsEngine        off
ControlsMaxClients    2
ControlsLog           /var/log/proftpd/controls.log
ControlsInterval      5
ControlsSocket        /var/run/proftpd/proftpd.sock
</IfModule>
<IfModule mod_ctrls_admin.c>
AdminControlsEngine off
</IfModule>
# Alternative authentication frameworks
#Include /etc/proftpd/ldap.conf
Include /etc/proftpd/sql.conf
# This is used for FTPS connections
Include /etc/proftpd/tls.conf
# Useful to keep VirtualHost/VirtualRoot directives separated
#Include /etc/proftpd/virtuals.con
# A basic anonymous configuration, no upload directories.
# <Anonymous ~ftp>
#   User                ftp
#   Group               nogroup
#   # We want clients to be able to login with "anonymous" as well as "ftp"
#   UserAlias           anonymous ftp
#   # Cosmetic changes, all files belongs to ftp user
#   DirFakeUser on ftp
#   DirFakeGroup on ftp
#   # Limit the maximum number of anonymous logins
#   MaxClients          10
#   # We want 'welcome.msg' displayed at login, and '.message' displayed
#   # in each newly chdired directory.
#   DisplayLogin        welcome.msg
#   DisplayChdir        .message
#   # Limit WRITE everywhere in the anonymous chroot
#   <Directory *>
#     <Limit WRITE>
#       DenyAll
#     </Limit>
#   </Directory>
#   # Uncomment this if you're brave.
#   # <Directory incoming>
#   #   # Umask 022 is a good standard umask to prevent new files and dirs
#   #   # (second parm) from being group and world writable.
#   #   Umask           022  022
#   #            <Limit READ WRITE>
#   #            DenyAll
#   #            </Limit>
#   #            <Limit STOR>
#   #            AllowAll
#   #            </Limit>
#   # </Directory>
# </Anonymous>
# Include other custom configuration files
Include /etc/proftpd/conf.d/
# Limit KeyHelp usergroup
<Limit LOGIN>
    DenyGroup OR keyhelp_noftp kh_suspended
</Limit>
AllowOverwrite on
UseReverseDNS off
IdentLookups off
DefaultRoot ~
AuthOrder mod_auth_pam.c* mod_auth_unix.c mod_auth_file.c
#AuthUserFile /etc/proftpd/ftpd.passwd
#AuthGroupFile /etc/proftpd/ftpd.group
Danke im Voraus :)
Re: ProFTPd zerstört
Frage zurück:
Was hast du denn gemacht?
Justin1804
Ich hatte den Tekbase Rootserver installiert.
b0snaX
Post by b0snaX »
Also ich habe auch TekBASE mit KeyHelp server aufgezogen und verlief ohne Problem. Du musst nur bei der Installation einfach auswäheln das TekBASE nicht apache usw. installieren soll. Dann klappt es auch ohne probleme.
Ich würde vorschlagen eine Neuinstallation des vServer oder Dedicated Servers nicht das TekBASE auch andere Dateien verändert hat und auf lange sicht auch andere Sachen nicht funktionieren. TekBASE ist ein Umfangreiche Software die sehr viel verändert.
Deshalb nutze ich das auch nicht mehr.
Schöne Grüße,
b0snaX
Justin1804
Naja, hatte ja nur Rootserver ausgewählt und nicht Webserver + Rootserver...
Lass doch die Profis ran.
Kost ja nix.
https://teklab.de/tekbase-webinterface/
Kostenlose Installation Unser neues Installskript übernimmt in der Regel die komplette Einrichtung des Servers. Sollte die Installation auf dem Linux Webserver bei Ihnen fehlerhaft sein, übernehmen wir für Sie kostenlos die Installation oder Fehlerbehebung.
Justin1804
Das gilt nur für die Kaufversion / Mietversion habe lediglich nur die LITE Version.
b0snaX
Post by b0snaX »
Hast du schonmal den Server neu gestartet komplett?
Schöne Grüße,
b0snaX
Justin1804
Nein, das habe ich noch nicht gemacht.
b0snaX
Post by b0snaX »
Mach das mal einen kompletten Server restart und dann wenn der server wieder da ist einfach einen FTP User anlegen und paar min warten.
Schöne Grüße,
b0snaX
Justin1804
Hat leider kein Erfolg gebracht :(
b0snaX
Post by b0snaX »
ich würde dir da Tatsächlich mal empfehlen noch mal ganz in ruhe von neu nazufangen also: Server neu installieren minimal, dann KeyHelp und dann mittels Automatischer installation TekBASE
https://community.teklab.de/thread/5778 ... enntnisse/
Schöne Grüße,
b0snaX
Justin1804
Re: ProFTPd zerstört  [GELÖST]
Hab es gefixt bekommen :)
Hab in einer Virtuellen Maschine KeyHelp installiert und dann diese Config kopiert, jetzt geht alles wieder. :)
Danke Trotzdem für die Hilfe.
