Auto renew ssl ... [SOLVED]
Nikitaidis
Re: Auto renew ssl ...
Nikitaidis
No.
You obtain the certificates within the domain-settings in the KeyHelp admin panel.
They renew automatically every three months.
Nikitaidis
It’s possible auto renew ssl every 2 month ?Tobi wrote: ↑Sun 28. Apr 2019, 16:43No.
Lets'Encrypt certificates are valid for 90 days. KeyHelp starts the renewal 30 days before. If this does not work, KeyHelp will try to get a new certificate every day. If there are only 20 days left before the expiration date, KeyHelp will send a notification to the administrator.
This is also configurable via KeyHelp: "Settings > Configuration > Security > SSL/TLS certificates" (sorry, I didn't switch to the English UI but translated it from German, so it might differ slightly).
Cheers,
Jan
