Automatic creating link for webmail and panel
webmedia
Post by webmedia »
Hi, I'm new here and I want to know can I somehow make that when I create some user and domain that automaticly creates a subdomain for webmail (webmail.clientdomain.com)with forwarding on the serverdomain.com/webmail and for keyhelp Panel too.So my goal is that they don't type the server domain to go to panel or webmail.
Re: Automatic creating link for webmail and panel
for KeyHelp itself, no such domain will be created. For webmail, a subdomain webmail.domain.tld is created by default which redirects to server webmail.
You could generate the fitting subdomains by yourself.
Then you can configure a proxy-forwarding to your webmail.
You can put the proxy directives in the field "advanced domain options".
Sorry, my panel is in german so maybe the field for the directives is called slightly different.
webmedia
Post by webmedia »
Sorry I made a wrong question.. It's not issue that webmail.domain.com is not created, issue is that that domain is with invalid SSL (missmatch - uses default from Keyhelp). How can we create valid (Let's Encrypt) SSL certificate for webmail.domain.com? Here is example https://webmail.akzenica.com
this is not possible. You can manually add SAN certificate for such domains (Secure Panel -> Webmail Domain in TLS section).
Default behaviour is to redirect to the server domain, which contains proper certificate.
Best Regards
Martin Dannehl
webmedia
Post by webmedia »
Ok thank you all for info! :)
