Cronjob to delete all emails older than one month from server.
luxusmind
Post by luxusmind »
First of all Happy holidays to all of you.
I am trying to setup a Cron Job that would delete emails older than one month, but until now i was unsuccessful.
I was using this tutorial while i had my websites hosted on cPanel. And would like to know if that's okay also with KeyHelp or should i do it in another way.
I have posted it instead of pointing to the link.
[root@EcLinux]# touch mailcleaner.sh
Edit the file using your favorite file editor
[root@EcLinux]# vim mailcleaner.sh
find /home/username/mail/yourdomain.com/*/cur -type f -mtime +30 -exec rm -f {} \;
:wq
Then change that file to an executable one. (ie file permission to 755)
[root@EcLinux]# chmod 755 /root/mailcleaner.sh
Step 2 : Creating CRON job
Next step is to set the cronjob under root (for setting a cronjob refer this link). Here I’m setting the cron job to run every 1 day of the month.
[root@EcLinux]# crontab -e
0 0 1 * * /root/mailcleaner.sh > /dev/null 2>&1
:wq
[root@EcLinux]# crontab -l : To list all cronjobs.
In this case the file mailcleaner.sh will execute first day of every month and remove all emails older than 30days.
Credits for the tutorial goes to: Crybit
Ibrahim
Re: Cronjob to delete all emails older than one month from server.
With KeyHelp, mails are stored at /var/mail/vhosts/<DOMAIN_PART>/<USERNAME_PART>/cur
So you have to update the path you are using in your mailcleaner.sh
luxusmind
Post by luxusmind »
Alexander wrote: Fri 21. Jun 2019, 08:02 Hello,
Thank you a lot for your response.
I'll post it here for future references, there may be other users that would surely search for it in future.
If you want to schedule a Cronjob and delete emails that are older than 30 days all you have to do is add the above command into your crontab.
crontab -e is used to edit cronjobs.
Add it anywhere you want, modify the domain.com with your domain name and the username with your desired email address.
* * * * * find /var/mail/vhosts/domain.com/username/cur -type f -mtime +30 -exec rm -f {} \; >/dev/null 2>&1
Thank you again Alexander.
Ibrahim
