Panel link for clients
webmedia
Post by webmedia »
Hello, I'm trying to set for every new created user to get the link for keyhelp panel but automaticly without manually making subdomain and redirecting it to my panel link.Is it possible somehow to be domain.com/panel and to redirect to my serveer/panel link?
nikko
Re: Panel link for clients
Post by nikko »
KH use a FQDN -not a subdomain- for the server and for login, like e.g. server.domain.com.
Every new created user get an email with this loginlink and the creditals.
webmedia
Post by webmedia »
So I can't make it automaticly like user has a domain example.com to be panel.example.com?
You can not do this automatically out of the box.
As a starter, some ideas - depending on your setup they might not be suitable / not complete!
If you want to go the "Path" way (eg. https://client-domain.com/keyhelp -> redirection to KeyHelp login):
You could create a cronjob, which regularly iterates over all user domain target folders (/home/users/*/www/...), and do either 1) or 2).
1) create a folder keyhelp/. Then put an index.php file into the created keyhelp/ folder with the content:
<?php
header('Location: https://<URL TO YOUR LOGIN>');
2) create a .htaccess with the content:
RewriteEngine On
RewriteRule ^keyhelp$ https://<URL TO YOUR LOGIN> [R=302,NE,L]
webmedia
Post by webmedia »
Great! Thanks for the info, do you have any example just to see how it goes with cronjob.
