Disable a user after they have excited monthly traffic  [SOLVED]
webmedia
Post by webmedia »
Hello once again
is there a way to automatically disable a user once they have used up their monthly traffic?
Thanks!
Re: Disable a user after they have excited monthly traffic  [SOLVED]
at the moment you can let yourself be notified when a user exceeds his traffic limit.
In this case, an email will be sent to an email address you specify.
You find the option under "Configuration" -> "Notifications".
webmedia
Post by webmedia »
Alexander wrote: Mon 19. Aug 2019, 14:33 Hello,
Thanks <3
