Error installing on Ubuntu 18.04
tom83
Post by tom83 »
I've tried to install KeyHelp on VULTR instance using fresh Ubuntu 18.04 and got this error:
Installation is running:
Update sources list ...                     [OKAY]
Installation requirements ...               [OKAY]
Sudo ...                                    [OKAY]
Bind9 ...                                   [OKAY]
SSL/TLS ...                                 [OKAY]
PHP ...                                     [OKAY]
Apache web server ...                       [OKAY]
PHP-FPM ...                                 [OKAY]
MariaDB ...                                 [OKAY]
KeyHelp ...                                 [OKAY]
Firewall ...                                [OKAY]
SSH ...                                     [OKAY]
ProFTPD ...                                 [OKAY]
Postfix ...                                 [OKAY]
Dovecot ...                                 [OKAY]
OpenDKIM ...                                [OKAY]
Email protection ...                        [OKAY]
AWStats ...                                 [OKAY]
Fail2ban ...                                [ERROR]
Logrotate ...                               [ERROR]
PhpMyAdmin 4.9.0.1 ...                      [OKAY]
Adminer 4.7.1 ...                           [OKAY]
Roundcube 1.3.9 Multilanguage ...           [OKAY]
Rainloop 1.13.0 (Community Edition) ...     [OKAY]
Quota ...                                   [ERROR]
Apparmor ...                                [ERROR]
7-zip ...                                   [ERROR]
Hide LTS notice ...                         [OKAY]
Update message of the day ...               [OKAY]
Nano ...                                    [ERROR]
Curl ...                                    [ERROR]
NTP ...                                     [ERROR]
Cron daemon ...                             [ERROR]
Errors occurred during installation!
For more information, see the log file:
/var/log/keyhelp/install.log
If you need help, please visit our multilingual support community:
https://community.keyhelp.de
You will find your login information on your server in the file:
/root/keyhelp_login_data_2019-08-22_19-26-57
Here are the file /var/log/keyhelp/install.log :
   _  __          _   _     _    (R)
  | |/ /___ _   _| |_| |___| |___
  | | /  -_) |_/ |  _  | -_) | _ \
  |_|\_\___|\__, |_| |_|___|_|  _/ Your Administration-Panel
=========== |___/ ========== |_| =========================================
Here you can customize installation parameters.
  Server data
    1) Hostname (FQDN):             keyhelp.mydomain.com
  Administrator account
    2) Username:                     keyadmin
    3) Password:                     mypassHere
    4) Email address:                my@mailaddress
  Server data
    5) Notification after finishing: No
- Available actions ------------------------------------------------------
  S)   Start install
  1-5) Edit data
  Q)   Quit install
Choose action [4]: S
   _  __          _   _     _    (R)
Sudo ...                                    [OKAY]
Bind9 ...                                   [OKAY]
SSL/TLS ...                                 [OKAY]
PHP ...                                     [OKAY]
PHP-FPM ...                                 [OKAY]
MariaDB ...                                 [OKAY]
KeyHelp ...                                 [OKAY]
Firewall ...                                [OKAY]
SSH ...                                     [OKAY]
ProFTPD ...                                 [OKAY]
Postfix ...                                 [OKAY]
Dovecot ...                                 [OKAY]
OpenDKIM ...                                [OKAY]
AWStats ...                                 [OKAY]
Quota ...                                   [ERROR]
7-zip ...                                   [ERROR]
Nano ...                                    [ERROR]
Curl ...                                    [ERROR]
NTP ...                                     [ERROR]
!!! Attention !!! The system will reboot in a few seconds (Cancel with CRTL+C).: 0
Connection to 136.244.84.54 closed by remote host.
Connection to 136.244.84.54 closed.
MacBook-Pro-de-Tom:~ tom$ ssh root@136.244.84.54
root@136.244.84.54's password:
Welcome to Ubuntu 18.04.2 LTS (GNU/Linux 4.15.0-55-generic x86_64)
 * Documentation:  https://help.ubuntu.com
 * Management:     https://landscape.canonical.com
 * Support:        https://ubuntu.com/advantage
  System information as of Thu Aug 22 19:35:31 UTC 2019
  System load:  0.08               Processes:           110
  Usage of /:   12.3% of 24.55GB   Users logged in:     0
  Memory usage: 50%                IP address for ens3: 136.244.84.54
  Swap usage:   0%
  This server is powered by KeyHelp!
  * Panel access:
      https://keyhelp.mydomain.com/ or https://136.244.84.54/
  * Login data:
21 packages can be updated.
9 updates are security updates.
Last login: Thu Aug 22 19:15:08 2019 from 131.100.93.59
root@keyhelp:~# vi /var/log/keyhelp/install.log
root@keyhelp:~# packet_write_wait: Connection to 136.244.84.54 port 22: Broken pipe
MacBook-Pro-de-Tom:~ Tom$ ssh root@136.244.84.54
  System information as of Thu Aug 22 19:53:59 UTC 2019
  System load:  0.01               Processes:           111
  Usage of /:   12.3% of 24.55GB   Users logged in:     1
  Memory usage: 55%                IP address for ens3: 136.244.84.54
  Swap usage:   0%
  * Panel access:
  * Login data:
Last login: Thu Aug 22 19:35:33 2019 from 131.100.93.59
root@keyhelp:~#
root@keyhelp:~#
root@keyhelp:~# vi /root/keyhelp_login_data_2019-08-22_19-26-57
  [SKIPPED DUE PREVIOUS ERRORS] exec  | ntpdate -u ntp.ubuntu.com
  [SKIPPED DUE PREVIOUS ERRORS] exec  | apt-get install -y ntp
  Cron daemon
  exec  | apt-get install -y cron
          Reading package lists...FATAL -> Failed to fork.
  [SKIPPED DUE PREVIOUS ERRORS] files | cron/keyhelp => /etc/cron.d/keyhelp
  [SKIPPED DUE PREVIOUS ERRORS] exec  | chmod 0644 /etc/cron.d/keyhelp
=> Errors occurred during installation. <=
Finished install: 2019-08-22 19:26:57
Duration: 298 second(s)
nikko
Re: Error installing on Ubuntu 18.04
Post by nikko »
Pls show us
Which virtualization is used?
KH only supports KVM, OpenVZ, dedicated.
tom83
Post by tom83 »
It's using KVM on VULTR.com Cloud instance.
I've posted the log file above.
(Now I've deleted this server and will try to install again)
tom83
Post by tom83 »
I've installed again on a fresh Ubuntu server and now worked fine the installation.
(I put "SUDO" on the installation code, not sure if was that the problem, but now worked without errors)
SUDO wget https://install.keyhelp.de/get_keyhelp.php -O installkeyhelp.sh ; bash installkeyhelp.sh ;
tom83
Post by tom83 »
I'm trying to install KeyHelp on a new fresh Ubuntu server and getting errors (AWStats, Fail2ban, Logrotate).
Using Ubuntu 18.04, KVM, on vultr.com instances.
I tried to install it 3 times. I also tried with "sudo" command and still problem. Here install log:
  Server data
    1) Hostname (FQDN):              testek.getcon.com.br
    2) Usuário:                      administrador
    3) Senha:                        nX1ufhAQSXd84Acy
    4) Email:                        root@testek.getcon.com.br
  Server data
    5) Notification after finishing: suporte@getcon.com.br
  S)   Start install
  1-5) Edit data
  Q)   Quit install
   _  __          _   _     _    (R)
  |_|\_\___|\__, |_| |_|___|_|  _/ Seu painel de administração
Sudo ...                                    [OKAY]
Bind9 ...                                   [OKAY]
SSL/TLS ...                                 [OKAY]
PHP ...                                     [OKAY]
PHP-FPM ...                                 [OKAY]
MariaDB ...                                 [OKAY]
KeyHelp ...                                 [OKAY]
Firewall ...                                [OKAY]
SSH ...                                     [OKAY]
ProFTPD ...                                 [OKAY]
Postfix ...                                 [OKAY]
Dovecot ...                                 [OKAY]
OpenDKIM ...                                [OKAY]
AWStats ...                                 [ERROR]
PhpMyAdmin 4.9.1 ...                        [OKAY]
Adminer 4.7.4 ...                           [OKAY]
Roundcube 1.3.10 Multilanguage ...          [OKAY]
Quota ...                                   [OKAY]
Apparmor ...                                [OKAY]
7-zip ...                                   [OKAY]
Nano ...                                    [OKAY]
Curl ...                                    [OKAY]
NTP ...                                     [OKAY]
Cron daemon ...                             [OKAY]
/root/keyhelp_login_data_2019-10-30_20-35-17
!!! Atenção !!! The system will reboot in a few seconds (Cancel with CRTL+C).: 22^C
root@testek:~#  vi /var/log/keyhelp/install.log
          Preparing to unpack .../awstats_7.6+dfsg-2_all.deb ...
          Unpacking awstats (7.6+dfsg-2) ...
          Setting up awstats (7.6+dfsg-2) ...
          Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
  [SKIPPED DUE PREVIOUS ERRORS] exec  | rm -f /etc/cron.d/awstats
  [SKIPPED DUE PREVIOUS ERRORS] exec  | rm -f /etc/awstats/awstats.conf
  Fail2ban
  exec  | apt-get install -y fail2ban
  [SKIPPED DUE PREVIOUS ERRORS] files | fail2ban/jail.d/keyhelp.local => /etc/fail2ban/jail.d/keyhelp.local
  [SKIPPED DUE PREVIOUS ERRORS] files | fail2ban/filter.d/keyhelp-phpmyadmin.conf => /etc/fail2ban/filter.d/keyhelp-phpmyadmin.conf
  [SKIPPED DUE PREVIOUS ERRORS] exec  | service fail2ban restart
  Logrotate
  exec  | apt-get install -y logrotate
  [SKIPPED DUE PREVIOUS ERRORS] files | logrotate/keyhelp-apache => /etc/logrotate.d/keyhelp-apache
tom83 wrote: Wed 30. Oct 2019, 21:41 Here install log:
That's not the install log.
Look here:
Jolinar wrote: Wed 30. Oct 2019, 22:37 That's not the install log.
You need to scroll down ;). Its all inside of the code box.
"FATAL -> Failed to fork."
@tom83, you may run out of memory. Do you have enough free memory available on your system?
Alexander wrote: Thu 31. Oct 2019, 00:01 You need to scroll down ;). Its all inside of the code box.
Oh sorry, my mistake. I've only seen the output from the install script in the top of the code box. :?
tom83
Post by tom83 »
1 GB RAM, 25 GB SSD, 1 TB traffic
What could be wrong?
nikko
Post by nikko »
Maybe that no Swap is installed, so you get OOM. Pls. use more than 1 GB
