are sites isoladed?
tom83
are sites isoladed?
Post by tom83 »
Just to know. If I get any website hacked, all other websites or server will be with problem too?
Are each website isoladed from each other?
Also, are the linux updates automatic?
I'm asking some questions because I'm planing to use KeyHelp in production for me and for clients.
Thanks and cheers.
Re: are sites isoladed?
each PHP process is running under it's keyhelp user. So by default it can only access files within this user.
There is a cronjob running, which takes care of those updates - performing apt-get update && apt-get upgrade on a regular basis.
tom83
Post by tom83 »
Thanks.
Why I'm not seeing any Email Accounts menu? Do I have to make anything before then I can create email accounts?
Isn't showing any option to create email accounts.
I've installed just for testing now, and will use in the future.
Cheers
The menu item "Email" will appear, when you assign the appropriate resources to the user.
Go to the user management -> click on the pen icon of the desired user -> go to the tab "resources & permissions" -> assign an appropriate number of email addresses and email accounts to him -> save the form.
The user should have a domain, suitable for assigning email addresses assigned to him.
tom83
Post by tom83 »
If I have 10 websites in the same user account. Then if one website gets hacked, other also could be?
The isolation if per just per user? Or also per domain/website? (I'm new to the panel).
So the ideal would be to create new user for each new website instead of creating all websites in the same user, right?
Thanks.
nikko
Post by nikko »
You are on the right way. Per user account.
tom83
Post by tom83 »
Would be great if the isolation could be per user and also per each application. Then less problems with hacks or security I guess. Maybe a feature request.
Best Regards.
nikko
Post by nikko »
Martin wrote: Fri 23. Aug 2019, 00:51 Hello,
Already done.
