habe einen vServer auf dem KeyHelp installiert ist. Läuft soweit alles gut - bis auf die Erstellung des Let's Encrypt Zertifikats für den KeyHelp-Zugriff - ausgestellt auf den Hostnamen (im folgenden Log my.hostname.de genannt). Die Let's Encrypt SSL Zertifikate für auf den Server aufgeschaltete Domains (im folgenden Log my-specific-domain.de genannt) funktionieren allerdings!
Anbei das Fehlerprotokoll:
[07-Nov-2019 00:00:12] INFO --> starting ssl certification maintenance
[07-Nov-2019 00:00:12] INFO --> checking (normal) SSL/TLS certificates
[07-Nov-2019 00:00:12] INFO --> check certificate "[ID 1]"
[07-Nov-2019 00:00:12] INFO --> certificate name is "default"
[07-Nov-2019 00:00:12] INFO --> certificate is valid until 2029-11-01 21:30:14 (3647 days left)
[07-Nov-2019 00:00:12] INFO --> checking lets encrypt certificates
[07-Nov-2019 00:00:12] INFO --> remove unused accounts / certificates
[07-Nov-2019 00:00:12] INFO --> check domain "my-specific-domain.de'
[07-Nov-2019 00:00:12] INFO --> certificate is valid until 2020-02-03 21:32:31 (88 days left)
[07-Nov-2019 00:00:12] INFO --> check domain "www.my-specific-domain.de'
[07-Nov-2019 00:00:12] INFO --> certificate is valid until 2020-02-03 21:32:52 (88 days left)
[07-Nov-2019 00:00:12] INFO --> check domain "my.hostname.de'
[07-Nov-2019 00:00:12] INFO --> certificate file does not exist
[07-Nov-2019 00:00:12] INFO --> renew cert
[07-Nov-2019 00:00:12] INFO --> Using certificate authority: "https://acme-v02.api.letsencrypt.org/" (LIVE).
[07-Nov-2019 00:00:12] INFO --> Getting endpoint URLs.
[07-Nov-2019 00:00:15] INFO --> Account "keyhelp" already registered. Continue.
[07-Nov-2019 00:00:15] INFO --> Requesting Key ID.
[07-Nov-2019 00:00:15] INFO --> Sending signed request to "https://acme-v02.api.letsencrypt.org/acme/new-acct".
[07-Nov-2019 00:00:18] INFO --> Start certificate generation.
[07-Nov-2019 00:00:18] INFO --> Local resolving checks of domains successfully completed.
[07-Nov-2019 00:00:18] INFO --> Requesting challenges for domain "my.hostname.de".
[07-Nov-2019 00:00:18] INFO --> Sending signed request to "https://acme-v02.api.letsencrypt.org/acme/new-order".
[07-Nov-2019 00:00:20] INFO --> Start authorization process for "my.hostname.de".
[07-Nov-2019 00:00:20] INFO --> Deploy challenge.
[07-Nov-2019 00:00:20] INFO --> Token stored at: /home/keyhelp/www/.well-known/acme-challenge/blablablablablablablablablablablabla
[07-Nov-2019 00:00:21] INFO --> Notify CA that the challenge is ready.
[07-Nov-2019 00:00:21] INFO --> Sending signed request to "https://acme-v02.api.letsencrypt.org/acme/chall-v3/1118734538/c5T5cg".
[07-Nov-2019 00:00:21] ERROR --> a lets encrypt error occurred: Curl: Unknown SSL protocol error in connection to acme-v02.api.letsencrypt.org:443 (https://acme-v02.api.letsencrypt.org/acme/new-nonce)
[07-Nov-2019 00:00:21] INFO --> send notification to admin "adminusername" (webmaster@somedomain.de)
[07-Nov-2019 00:00:21] INFO --> finished
