Server Failure  [SOLVED]
smied
Server Failure
Post by smied »
24 hours = 3 failures
Server stops responding (ping works)
Login to the server fails, as well as to sites connected to keyhelp.
After some time, when trying to enter the server, an error is issued:
MySQL - Connection Error: 2002 (Connection refused)
Only restarting via ssh helps
Server: 2 cores 1 ram
(2 sites Attendance 5.000 users per day)
Re: Server Failure  [SOLVED]
Sounds like an OOM kill.
Relevant logfile entries?
Re: Server Failure
this can not be aswered from our side, you may contact your datacenter support in this case.
smied
Re: Server Failure
Post by smied »
Jolinar wrote: Tue 26. Nov 2019, 11:00 Sounds like an OOM kill.
grep "Killed process" /var/log/syslog
Killed process 614 (mysqld)
https://www.keyhelp.de/en/
The site says this:
Please note the following installation requirements:
Operating system: Ubuntu LTS or Debian
Memory: At least 1 GB RAM
So how much then do you need?
for attendance of 5/10/30 thousand people per day
Re: Server Failure
smied wrote: Tue 26. Nov 2019, 12:37 The site says this:
That's the absolutely minimum you should have for the system to work.
smied wrote: Tue 26. Nov 2019, 12:37 So how much then do you need?
I think, you need at least 2GB RAM or more.
