apache not restarting
tom83
Post by tom83 »
My Keyhelp panel is down. And I can't restart apache:
root@server:~# systemctl restart apache2
Job for apache2.service failed because the control process exited with error code.
See "systemctl status apache2.service" and "journalctl -xe" for details.
Here error:
-- Unit apache2.service has begun starting up.
Dec 09 16:05:01 server.windows2019-update.tk apachectl[2808]: AH00526: Syntax error on line 35 of /etc/a
Dec 09 16:05:01 server.windows2019-update.tk apachectl[2808]: SSLCertificateFile: file '/etc/ssl/keyhelp
Dec 09 16:05:01 server.windows2019-update.tk apachectl[2808]: Action 'start' failed.
Dec 09 16:05:01 server.windows2019-update.tk apachectl[2808]: The Apache error log may have more informa
Dec 09 16:05:01 server.windows2019-update.tk systemd[1]: apache2.service: Control process exited, code=e
Dec 09 16:05:01 server.windows2019-update.tk systemd[1]: apache2.service: Failed with result 'exit-code'
Dec 09 16:05:01 server.windows2019-update.tk systemd[1]: Failed to start The Apache HTTP Server.
-- Subject: Unit apache2.service has failed
-- Defined-By: systemd
-- Support: http://www.ubuntu.com/support
-- Unit apache2.service has failed.
-- The result is RESULT.
Dec 09 16:05:01 server.windows2019-update.tk sudo[2803]: pam_unix(sudo:session): session closed for user
Dec 09 16:05:01 server.windows2019-update.tk sudo[2836]:     root : TTY=unknown ; PWD=/root ; USER=root
Dec 09 16:05:01 server.windows2019-update.tk sudo[2836]: pam_unix(sudo:session): session opened for user
Dec 09 16:05:01 server.windows2019-update.tk sudo[2836]: pam_unix(sudo:session): session closed for user
Dec 09 16:05:02 server.windows2019-update.tk CRON[2785]: pam_unix(cron:session): session closed for user
Seems to be something related to SSL, not sure. Any ideas?
I'm using cloudflare to manage DNS.
Re: apache not restarting
tom83
Post by tom83 »
Here:
● apache2.service - The Apache HTTP Server
   Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor preset: enabled)
  Drop-In: /lib/systemd/system/apache2.service.d
           └─apache2-systemd.conf
   Active: failed (Result: exit-code) since Mon 2019-12-09 17:01:12 -03; 32s ago
  Process: 2686 ExecStart=/usr/sbin/apachectl start (code=exited, status=1/FAILURE)
Dec 09 17:01:12 server.windows2019-update.tk systemd[1]: Starting The Apache HTTP Server...
Dec 09 17:01:12 server.windows2019-update.tk apachectl[2686]: AH00526: Syntax error on line 35 of /etc/apache2/keyhelp/keyhelp.conf
Dec 09 17:01:12 server.windows2019-update.tk apachectl[2686]: SSLCertificateFile takes one argument, SSL Server Certificate file
Dec 09 17:01:12 server.windows2019-update.tk apachectl[2686]: Action 'start' failed.
Dec 09 17:01:12 server.windows2019-update.tk apachectl[2686]: The Apache error log may have more information.
Dec 09 17:01:12 server.windows2019-update.tk systemd[1]: apache2.service: Control process exited, code=exited status=1
Dec 09 17:01:12 server.windows2019-update.tk systemd[1]: apache2.service: Failed with result 'exit-code'.
Dec 09 17:01:12 server.windows2019-update.tk systemd[1]: Failed to start The Apache HTTP Server.
And here:
root@server:~# journalctl -xe
Dec 09 17:03:01 server.windows2019-update.tk apachectl[2800]: AH00526: Syntax error on line 35 of /etc/apache2/keyhelp/keyhelp.c
Dec 09 17:03:01 server.windows2019-update.tk apachectl[2800]: SSLCertificateFile takes one argument, SSL Server Certificate file
Dec 09 17:03:01 server.windows2019-update.tk apachectl[2800]: Action 'start' failed.
Dec 09 17:03:01 server.windows2019-update.tk apachectl[2800]: The Apache error log may have more information.
Dec 09 17:03:01 server.windows2019-update.tk systemd[1]: apache2.service: Control process exited, code=exited status=1
Dec 09 17:03:01 server.windows2019-update.tk systemd[1]: apache2.service: Failed with result 'exit-code'.
Dec 09 17:03:01 server.windows2019-update.tk systemd[1]: Failed to start The Apache HTTP Server.
Dec 09 17:03:01 server.windows2019-update.tk sudo[2795]: pam_unix(sudo:session): session closed for user root
Dec 09 17:03:01 server.windows2019-update.tk sudo[2829]:     root : TTY=unknown ; PWD=/root ; USER=root ; COMMAND=/usr/sbin/serv
Dec 09 17:03:01 server.windows2019-update.tk sudo[2829]: pam_unix(sudo:session): session opened for user root by (uid=0)
Dec 09 17:03:01 server.windows2019-update.tk sudo[2829]: pam_unix(sudo:session): session closed for user root
Dec 09 17:03:01 server.windows2019-update.tk CRON[2777]: pam_unix(cron:session): session closed for user root
Dec 09 17:03:10 server.windows2019-update.tk postfix/qmgr[2292]: 1FDE45FE17: from=<double-bounce@server.windows2019-update.tk>,
Dec 09 17:03:10 server.windows2019-update.tk postfix/qmgr[2292]: 805EA5FE22: from=<double-bounce@server.windows2019-update.tk>,
Dec 09 17:03:10 server.windows2019-update.tk dovecot[2846]: lda(root@server.windows2019-update.tk): Error: userdb lookup: connec
Dec 09 17:03:10 server.windows2019-update.tk dovecot[2846]: lda: Fatal: Internal error occurred. Refer to server log for more in
Dec 09 17:03:10 server.windows2019-update.tk dovecot[2848]: lda(root@server.windows2019-update.tk): Error: userdb lookup: connec
Dec 09 17:03:10 server.windows2019-update.tk dovecot[2848]: lda: Fatal: Internal error occurred. Refer to server log for more in
Dec 09 17:03:10 server.windows2019-update.tk postfix/pipe[2845]: 1FDE45FE17: to=<root@server.windows2019-update.tk>, orig_to=<po
Dec 09 17:03:10 server.windows2019-update.tk postfix/pipe[2847]: 805EA5FE22: to=<root@server.windows2019-update.tk>, orig_to=<po
lines 2124-2151/2151 (END)
derFu
Post by derFu »
And what does /etc/apache2/error.log say?
tom83
Post by tom83 »
I don't have this log file (it's empty):
root@server:/etc/apache2# ls
apache2.conf       conf-available  envvars  magic           mods-enabled  sites-available  suexec
apache2.conf.save  conf-enabled    keyhelp  mods-available  ports.conf    sites-enabled
root@server:/etc/apache2# vi /etc/apache2/error.log
derFu
Post by derFu »
tom83 wrote: Mon 9. Dec 2019, 21:26 I don't have this log file (it's empty):
Sorry, my fault, it's /var/log/apache2/error.log
tom83
Post by tom83 »
Empty log file:
root@server:~# cat /var/log/apache2/error.log
root@server:~#
The first error occurs here:
Please check this file.
