Unable to find a valid quota mount point  [SOLVED]
Nikitaidis
Post by Nikitaidis »
Hello
i have OpenVZ Ubuntu 18.04 i get Error:
installing ionCube...
2019-12-24 14:57:50 URL:http://downloads3.ioncube.com/loader_do ... -64.tar.gz [12619060/12619060] -> "/tmp/ioncube.tar.gz" [1]
Run /home/keyhelp/www/keyhelp/install/install.php --installer-version 1
Error: Unable to find a valid quota mount point. You have to make sure that there is a "/" - mount point in your "/etc/fstab". If you need help, please visit our multilingual support community: https://community.keyhelp.de
Re: Unable to find a valid quota mount point  [SOLVED]
you should have the following line in your /etc/fstab when you are using OpenVZ:
/dev/simfs / simfs rw,relatime,usrquota,grpquota 0 0
matechserv2
Post by matechserv2 »
I have the same problem here, I have already tried everything. I have installed and re-install many times Keyhelp with all OK except Quota and still have error in quota and I can't create FTP user or file manager.
My VPS extra info:
root@s******:~# hostnamectl
   Static hostname: *****.*****.************.de
         Icon name: computer-container
           Chassis: container
        Machine ID: 0*************************************26
           Boot ID: 8****************************************e
    Virtualization: lxc
  Operating System: Debian GNU/Linux 10 (buster)
            Kernel: Linux 4.20.8-1.el7.elrepo.x86_64
      Architecture: x86-64
My output in /mount:
root@s10serverde:~# mount
 /dev/loop10 on / type ext4 (rw,relatime)
none on /dev type tmpfs (rw,relatime,size=492k,mode=755,uid=1000000,gid=1000000)
proc on /proc type proc (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
devtmpfs on /dev/fuse type devtmpfs (rw,nosuid,size=16437640k,nr_inodes=4109410,mode=755)
devtmpfs on /dev/net/tun type devtmpfs (rw,nosuid,size=16437640k,nr_inodes=4109410,mode=755)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
mqueue on /dev/mqueue type mqueue (rw,relatime)
tmpfs on /dev/lxd type tmpfs (rw,relatime,size=100k,mode=755)
tmpfs on /dev/.lxd-mounts type tmpfs (rw,relatime,size=100k,mode=711)
lxcfs on /proc/cpuinfo type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
lxcfs on /proc/diskstats type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
lxcfs on /proc/meminfo type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
lxcfs on /proc/stat type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
lxcfs on /proc/swaps type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
lxcfs on /proc/uptime type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
devtmpfs on /dev/full type devtmpfs (rw,nosuid,size=16437640k,nr_inodes=4109410,mode=755)
devtmpfs on /dev/null type devtmpfs (rw,nosuid,size=16437640k,nr_inodes=4109410,mode=755)
devtmpfs on /dev/random type devtmpfs (rw,nosuid,size=16437640k,nr_inodes=4109410,mode=755)
devtmpfs on /dev/tty type devtmpfs (rw,nosuid,size=16437640k,nr_inodes=4109410,mode=755)
devtmpfs on /dev/urandom type devtmpfs (rw,nosuid,size=16437640k,nr_inodes=4109410,mode=755)
devtmpfs on /dev/zero type devtmpfs (rw,nosuid,size=16437640k,nr_inodes=4109410,mode=755)
devpts on /dev/console type devpts (rw,relatime,gid=5,mode=620,ptmxmode=666)
none on /proc/sys/kernel/random/boot_id type tmpfs (ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=1000000,gid=1000000)
devpts on /dev/pts type devpts (rw,relatime,gid=1000005,mode=620,ptmxmode=000)
devpts on /dev/ptmx type devpts (rw,nosuid,noexec,relatime,gid=1000005,mode=620,ptmxmode=000)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,uid=1000000,gid=1000000)
tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755,uid=1000000,gid=1000000)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k,uid=1000000,gid=1000000)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755,uid=1000000,gid=1000000)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/usr/lib/systemd/systemd-cgroups-agent,name=systemd)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/rdma type cgroup (rw,nosuid,nodev,noexec,relatime,rdma)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset,clone_children)
cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio)
cgroup on /sys/fs/cgroup/hugetlb type cgroup (rw,nosuid,nodev,noexec,relatime,hugetlb)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
none on /run/shm type tmpfs (rw,relatime,uid=1000000,gid=1000000)
tmpfs on /run/user/0 type tmpfs (rw,nosuid,nodev,relatime,size=100000k,mode=700,uid=1000000,gid=1000000)
Also:
root@*******:~# cat /proc/mounts | grep ' / '
/dev/loop10 / ext4 rw,relatime 0 0
and in /etc/fstab I have already added the "line" you provide.
/vz/private/176     /dev     simfs     rw,relatime,usrquota,grpquota     0     1
LABEL=DOROOT  /dev ext4  errors=remount-ro,usrquota  0 1
simfs     /dev     simfs     rw,relatime,usrquota,grpquota     0     1
proc /proc proc defaults 0 0
none /dev/pts devpts rw,gid=5,mode=620 0 0
none /run/shm tmpfs defaults 0 0
Seems my home quota directory is /dev/loop10 right?
