Domain Bereich nicht nutzbar  [GELÖST]
rnssystems
Post by rnssystems »
seit dem letzten Keyhelp update kann man als "normaler" Benutzer den Bereich "Domain" nicht mehr nutzen.
In der /var/log/keyhelp/php-error.log findet man foldenden Fehler:
[16-Jan-2020 11:42:21 Europe/Berlin] PHP Fatal error:  Uncaught exception 'Twig\Error\RuntimeError' with message 'The merge filter only works with arrays or "Traversable", got "NULL" as first argument.' in /home/keyhelp/www/keyhelp/theme/default/domains.twig:13
Stack trace:
#0 /home/keyhelp/www/keyhelp/cache/32/3284043d04ff3f0368816b5e187bafd7650b22d74c5ef8dd6ecfd9c382ba1f04.php(65): twig_array_merge(NULL, Array)
#1 /home/keyhelp/www/keyhelp/vendor/twig/twig/src/Template.php(216): __TwigTemplate_7df528f4a36700fda9e11905e42239aa5b5dcdd0314ed33cc1dca922f5220ab6->block_content(Array, Array)
#2 /home/keyhelp/www/keyhelp/cache/5a/5af7d05811dea525a05ad5aed1927f9b2d0d6499c08af95af61658858e3f55e5.php(132): Twig\Template->displayBlock('content', Array, Array)
#3 /home/keyhelp/www/keyhelp/vendor/twig/twig/src/Template.php(216): __TwigTemplate_e617a484ef9c26f22a735a60c4dcbee2816283a42c6bfdb30fdbe996d4cdf511->block_body_content(Array, Array)
#4 /home/keyhelp/www/keyhelp/cache/31/31e9a39cd7d1b7d078d0d76c4ab6457c79941d79d7c8fa711f42f0c535653517.php(148): Twig\Template->displayBlock('body_content', Array, Array)
#5 /home/keyhelp/www/keyhelp/vendor/twig/twig/src/Template.php(455): __TwigTemplate_8a58a4540a5a6999503748ef3a5336948ca8318822b5752828d74ae269c3d377->doDisplay(Array, Array)
#6 /home/keyhelp/www/keyhelp/vendor/twig/twig/src/Template.php(422): Twig\Template->displayWithErrorHandling(Array, Array)
#7 /home/keyhelp/www/keyhelp/cache/5a/5af7d05811dea525a05ad5aed1927f9b2d0d6499c08af95af61658858e3f55e5.php(36): Twig\Template->display(Array, Array)
#8 /home/keyhelp/www/keyhelp/vendor/twig/twig/src/Template.php(455): __TwigTemplate_e617a484ef9c26f22a735a60c4dcbee2816283a42c6bfdb30fdbe996d4cdf511->doDisplay(Array, Array)
#9 /home/keyhelp/www/keyhelp/vendor/twig/twig/src/Template.php(422): Twig\Template->displayWithErrorHandling(Array, Array)
#10 /home/keyhelp/www/keyhelp/cache/32/3284043d04ff3f0368816b5e187bafd7650b22d74c5ef8dd6ecfd9c382ba1f04.php(35): Twig\Template->display(Array, Array)
#11 /home/keyhelp/www/keyhelp/vendor/twig/twig/src/Template.php(455): __TwigTemplate_7df528f4a3 in /home/keyhelp/www/keyhelp/theme/default/domains.twig on line 13
Wir nutzen noch PHP 5.6.40
Kann mir jemand helfen?
Julian
BloodOfPanda
Re: Domain Bereich nicht nutzbar
Post by BloodOfPanda »
Euer Host System läuft auf PHP 5.6.40? Welches OS benutzt Ihr?
Grüße Panda // Marcel
EDIT:
Hintergrund meiner Frage ist das KeyHelp ganz klar sagt: "Die Installation muss auf einem sauberen System (Minimal-Image), frei von installierter / konfigurierter Software erfolgen." KeyHelp nutzt meines wissen für PHP, SQL etc die Daten aus den Repros ergo. sollte da eig. kein PHP 5.6.40 rumkommen.
rnssystems
Es ist ein Debian Jessie.
Da hier legacy Anwendungen laufen ist ein Update auf ein neueres Debian schwierig.
Re: Domain Bereich nicht nutzbar  [GELÖST]
bitte einmal auf das neue Theme wechseln, im alten Theme gibt es bei der Domainverwaltung einen Bug.
KeyHelp Admin-Bereich -> Theme. Hier das obere Theme wählen.
Wie bereits mehrfach angekündigt: Das alte Theme wird in einem der kommenden Updates entfernt. Es erfolgt in dem Fall eine Zwangsumstellung auf das neue Theme.
