Not possible to add SSL for webmail subdomain?
prune
Post by prune »
Its not possible to add SSL for webmail.userdomain.com since its only cname...
Only possible way to login with SSL is to use https://adminpanel.com/webmail
Why cant KH do it the same as cpanel wherein panel and webmail logins can be in SSL and as subdirectory of any hosted user domain
https://userdomain.com/login
https://userdomain.com/webmail
Also, default self-signed SSL has KH info there...
Re: Not possible to add SSL for webmail subdomain?
You can use Apache modproxy to set up userdomain.com/login and /webmail.
There is a (german) howto on the board.
Is your German good enough?
prune
Post by prune »
Thank you! May you pls link me? I will use translator and try to figure it out.
