can't send emails
tom83
can't send emails
Post by tom83 »
I've installed on a brand new server, the last version of KeyHelp (20.0), on Ubuntu 18.04.
Problem is that I can't send emails. I already had contact with server provider, and is not blocked anything.
When I try to send email, it goes on Mail Queue, and gives error, for example:
connect to alt4.gmail-smtp-in.l.google.com[*****]:25: Connection timed out
I'm using CloudFlare but I've pointed all DNS records (spf, txt, dkim,...).
Do I need to unblock anything in the KeyHelp panel to send emails?
Congratulations to all team.
Thanks.
tom83
Re: can't send emails
Post by tom83 »
I've made the exact same new installation Ubuntu 18.04 and last KH version, and now seems to be working.
Not sure what happened, but just worked now.
gustavohellwig
Post by gustavohellwig »
tom83 wrote: Wed 19. Feb 2020, 13:53 Hi,
Thanks.
Which VPS provider are you using?
sanxh
Post by sanxh »
Me now using hetzner, I receive but I cannot send email
sanxh wrote: Fri 18. Mar 2022, 20:45 I cannot send email
Logfile entries?
sanxh
Post by sanxh »
Received: from localhost (localhost [127.0.0.1])
        by ***** (Postfix) with ESMTP id 6C5487EE53
        for <*****>; Wed, 16 Mar 2022 21:56:54 +0000 (UTC)
X-Virus-Scanned: Debian amavisd-new at *****
Received: from *****([127.0.0.1])
        by localhost (***** [127.0.0.1]) (amavisd-new, port 10024)
        with ESMTP id Q1FLHFCq4d08 for <*****>;
        Wed, 16 Mar 2022 21:56:53 +0000 (UTC)
Received: from ***** (localhost [127.0.0.1])
        by ***** (Postfix) with ESMTPSA id 8EC4F7EE51
        for <*****>; Wed, 16 Mar 2022 21:56:53 +0000 (UTC)
DKIM-Signature: v=1; a=rsa-sha256; c=relaxed/relaxed; d=*****;
        s=default; t=1647467813;
        bh=agXLDIY2bo0IMSnLUMp62eGDVz3Pe5fSPEdPqrwa3vo=;
        h=Date:From:To:Subject:From;
        b=a8dsvHBOoZnkpZ9Nw+6jyVlUzIqWPkyYFiaWZAopfeSdYrG6N/E2cbfS67z5uIE6R
         tzFzvifaBmcRh18VmipoA0nkoFR7WRNUp64pzLfD/vm+wQh/6wNhXvpICkT8v2kem9
         cckje2OvVbXV10yITf16Bn8VFwQUBw7BLX0ieOwgXzFIW739p6Sm7XIAoemgfyn8u1
         B24CXugnO1QjahrXCL/bzPtReZuI7xfNEwa6k2DBoDGjlEcdK3kwudaLYxzFwTzl12
         +zqj/cVnjUFCPXF251ak2/C81syJ6nr+yRasnz9CTculw/xLT3WJ6rGCuFekJtjrQU
         z7Ehg1HN25o3w==
MIME-Version: 1.0
Date: Thu, 17 Mar 2022 02:26:53 +0430
To: *****
Subject: Your mailbox has been setup successfully!
Message-ID: <*****>
X-Sender: *****
Content-Type: multipart/alternative;
 boundary="=_cb69f65d6193152199a0fb89a8ac2cc2"
Mod-Edit:
Post formatted
Sorry, but this is a mail header.
To identify the problem, i need corresponding entries from the log file (mail.log).
sanxh
Post by sanxh »
Where Can I find mail.log?
sanxh wrote: Fri 18. Mar 2022, 21:16 Where Can I find mail.log?
Sorry, but you are the administrator of the server. So you must know, where the log files are located.
I think you should have a look in /var/log
sanxh
Post by sanxh »
see attach
Do you understand the meaning of "corresponding entries"?
You have provided a complete log file.
These are the corresponding entries for the mail header you specified previously:
Mar 16 21:56:54 panel postfix/smtpd[10464]: connect from localhost[127.0.0.1]
Mar 16 21:56:54 panel postfix/smtpd[10464]: 6C5487EE53: client=localhost[127.0.0.1]
Mar 16 21:56:54 panel postfix/cleanup[10457]: 6C5487EE53: message-id=<*****>
Mar 16 21:56:54 panel postfix/smtpd[10464]: disconnect from localhost[127.0.0.1] ehlo=1 mail=1 rcpt=1 data=1 quit=1 commands=5
Mar 16 21:56:54 panel postfix/qmgr[10034]: 6C5487EE53: from=<*****>, size=2973, nrcpt=1 (queue active)
Mar 16 21:56:54 panel amavis[2388]: (02388-02) Passed CLEAN {RelayedOpenRelay}, [127.0.0.1]:34032 <*****> -> <*****>, Queue-ID: 8EC4F7EE51, Message-ID: <*****>, mail_id: Q1FLHFCq4d08, Hits: -0.798, size: 2455, queued_as: 6C5487EE53, 748 ms
Mar 16 21:56:54 panel postfix/smtp[10458]: 8EC4F7EE51: to=<*****>, relay=127.0.0.1[127.0.0.1]:10024, delay=0.89, delays=0.12/0.01/0.01/0.75, dsn=2.0.0, status=sent (250 2.0.0 from MTA(smtp:[127.0.0.1]:10025): 250 2.0.0 Ok: queued as 6C5487EE53)
and these entries say that the mail was sent.
Have you looked in the spam folder of the recipient?
sanxh
Post by sanxh »
connect to alt2.gmail-smtp-in.l.google.com[*****]:25: Connection timed out
But I can receive emails
You have several problems in your DNS configuration:
Please correct this first, then test again.
You can check your new DNS settings at different online services, i.e. -> https://mxtoolbox.com/emailhealth
l_fish
Post by l_fish »
Jolinar wrote: Fri 18. Mar 2022, 21:53
No, it just says that the mail was delivered to a service running locally on the same server on port 10024 (whatever this is). ;)
sanxh wrote: Fri 18. Mar 2022, 22:17 connect to alt2.gmail-smtp-in.l.google.com[*****]:25: Connection timed out
Since you're using Hetzner: They're blocking outgoing port 25 for the first month (until first invoice is paid) on their cloud servers. Maybe this is the main cause for your problem?
l_fish wrote: Sat 19. Mar 2022, 21:37 No, it just says that the mail was delivered to a service running locally on the same server on port 10024 (whatever this is). ;)
# netstat -luntep|grep 10024
tcp        0      0 127.0.0.1:10024         0.0.0.0:*               LISTEN      116        14023      538/amavisd-new (ma
tcp6       0      0 ::1:10024               :::*                    LISTEN      116        14024      538/amavisd-new (ma
