File manager - increase upload file size?
prune
Post by prune »
The default is 64M. I dont see any option for it in Admin > Settings > Configuration > Tools > File manager
I already changed User administration > Edit user > Php > upload_max_filesize to 150M but it doesnt affect File manager?
Im trying to upload a 140 mb zip.
Also where are the Php options like composer that you usually can un/check in Cpanel?
Thanks!
Re: File manager - increase upload file size?
have a look into the following file, which is responsible for the KeyHelp UI:
/etc/php/<PHP-VERSION>/fpm/pool.d/keyhelp.conf
After modifying this file, restart the PHP-FPM:
service php<PHP-VERSION>-fpm restart
prune
Post by prune »
Thank you I will check this out. Hopefully in future this can be tweaked within admin panel.
prune
Post by prune »
I already increase it to 150M but now I get this from Cloudflare. My KH is behind cloudflare
413 Request Entity Too Large
Im upload a 138 mb zip.
php_admin_value[memory_limit] = 128M
php_admin_value[post_max_size] = 150M
php_admin_value[upload_max_filesize] = 150M
php_admin_value[max_execution_time] = 180
php_admin_value[max_input_vars] = 2000
prune
Post by prune »
I grey cloud my domain in cloudflare and tried again but now I get
This page isn’t working right now
<mysite> can't currently handle this request.
HTTP ERROR 500
Maybe upload time out? How to increase time out? Modify this max_execution_time ?
prune
Post by prune »
Im still geting http error 500, i already disabled the cloudflare cloud for my domain for over 12 hrs now.
prune
Post by prune »
When creating new subdomain then creating a directory for it File manager then I upload a zip there, I get this error on 1st try
503 service unavailable
Service Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
On 2nd try it is a success. Just a zip below 20 mb.
chaiavi
Post by chaiavi »
I had a problem and although I defined a 500mb upload in the UI, it failed on about 120mb files or larger.
Looking it the logs, it seems that uploading of a single large file in the File manager fails as it tries to allocate all memory for the file.
Which means that even if you can define a max upload of 500mb, in fact it means that 500mb can be uploaded only having multiple files, but for a single file the limit is the max memory for PHP or something like that
I am attaching my log:
PHP Fatal error:  Allowed memory size of 134217728 bytes exhausted (tried to allocate 217773032 bytes) in /home/keyhelp/www/keyhelp/pages/user_file_manager.php on line 338
The value of the specific user is not relevant in this case.
When using the KeyHelp UI, only the settings of the "keyhelp" system user (the one running the KeyHelp UI) are relevant.
Its configuration can only be updated here:
Update these values as you wish.
php_admin_value[post_max_size] = 70M
php_admin_value[upload_max_filesize] = 64M
Afterwards restart / reload the PHP-FPM daemon.
chaiavi
Post by chaiavi »
Thank you very much!
