Port 22 ssh
Tony20
Port 22 ssh
Post by Tony20 »
Hello, Before I install the panel, I want to know this.
I installed Ubuntu18.04
I changed port 22 to another higher number.
Can I install KH panel using a different SSH port?
I need to do something also? will it work?
Tony.
Re: Port 22 ssh
You better change the port AFTER installation.
Tony20
Re: Port 22 ssh
Post by Tony20 »
Thanks Tobi!
I did the Installation, and everything went fine.
