How to change default PHP interpreter?
Re: How to change default PHP interpreter?
No, because the functionality of the panel is optimized for the default PHP version.
This is the right way.
- OlliTheDarkness
Changed for the Server or for the Domain ?
Right Way: Login as admin >> Domains >> Edit Domain >> PHP-Interpreter >> change PHP Version >> Save ...
Now wait ~60 Seconds and it run ... normaly
Should I install the latest - currently 7.4.3 or something) and attempt to use the latest version for each site ?
Or is it recommended to stick to the v7.2 default version ?
- OlliTheDarkness
Everyone as he needs it.
Personally, I use the default of the OS in productive operation.
To develop and tinker, mostly the latest available.
Everyone has to decide for themselves.
- OlliTheDarkness
At least not that I consciously noticed them.
The only negative is that some old-established functions have been blown out, but you already know that.
- OlliTheDarkness
Shows you all current configuration settings.
info.php
<?php
phpinfo();
- OlliTheDarkness
Then you call them up as normal via the browser.
You will be shown all PHP values e.g. loaded modules etc., including the path to the php.ini used.
