www not found
prune
www not found
Post by prune »
When I visit domain.com, I get the site. When I visit www.domain.com, I get not found. Why? I already set a cname for www pointing to domain.com in cloudflare.
Re: www not found
Is the subdomain "www" activated on your server?
prune
Re: www not found
Post by prune »
Hi Obito
No, I didnt create that subdomain. So I should create it and point it also the web folder of domain.com ?
The cname www entry in cloudflare or the * entry in dns management of keyhelp not enough?
Re: www not found
prune wrote: Sat 23. May 2020, 12:22 So I should create it and point it also the web folder of domain.com ?
Yes, that's now the right way.
BTW:
When you add a new Domain, you have an option "Create www. subdomain".
prune
Re: www not found
Post by prune »
Is there a way to just redirect www to the non-www like in cpanel? Since in cpanel even when you dont have the www created (folder) and as long as your cname www points to the @ domain.com, visiting the www.domain.com will show you domain.com
nikko
Re: www not found
Post by nikko »
Sure. Take a look into the options of your www. Domain
